Home > Technical > Is it possible? (EGR disconnetted)
Page 2 of 3 <123>
dgardel
Italy
vinsell wrote:
willy eckerslike wrote:
3 start cycles and the light will come on.
You're right. Light is on. Sad
P1402 and P1409.
When I had a 300tdi Disco I removed egr and its ecu. Do You think it should be possible to convert puma engine into an engine without electronics?
I'm sorry for the stupid question.
Vinicio
Let the light ON and drive with a "clean" intake engine (like me, now my Defender have 61000km, 58000 with egr not connected......) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #61948 3rd Mar 2011 9:25am
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
P1402 and P1409.
Vinicio
Ciao Daniele,
what about fuel consumption with egr disconnected?
Vinicio
Post #61951 3rd Mar 2011 9:27am
mse
I have a 300 still and its always stuck in my mind.
If i have the 300 (or the old vCool in the garage i cant run them as they will choke me...but the 90 can run in the garage (loosely) fine...what does that say about pollutants of new vs old engines.
But the thing that sticks in my mind is this, surely if you do 30mpg in a 3.5v8 or a 5l v8 or a 1l 4c - then you are buring 1gallon per 30 miles? so how can that be worse (or better) regardless of the co2 content... Mike
Post #61953 3rd Mar 2011 9:29am
vinsell
Here it's the fraud Thumbs Up .
Post #61957 3rd Mar 2011 9:35am
dgardel
Italy
P1402 and P1409.
Vinicio
Ciao Daniele,
Vinicio
not verified at the time, but I presume 2-3 mpg more... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #61960 3rd Mar 2011 10:05am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
[quote="mse life and death - you take the equipment required to resolve the problem...in an engine with electronics you just add some electronic bits, no different to throwing in a gasket etc.
[/quote]
Mmm, dunno about this - there's a huge difference between "throwing in a gasket" and "throwing in a few modern electronic components".
The complex electronics and engine management are the ONLY reasons why i wouldn't take my Defender up to Angola, Zambia, etc. Sure, easy countries like Botswana and Mozambique yes, but no further North than that.
I understand and appreciate the advantages when you're out in the sticks having fun, but for overlanding in Africa you'd be looking for trouble i reckon..., and (for me) i'd like to explore the possibility of removing some of the very advanced electronics - Africa's a great place to explore (in a super reliable vehicle).
Cheers www.ralton.co.za
Post #61969 3rd Mar 2011 10:49am
Naks
ralton wrote:
The complex electronics and engine management are the ONLY reasons why i wouldn't take my Defender up to Angola, Zambia, etc. Sure, easy countries like Botswana and Mozambique yes, but no further North than that. I understand and appreciate the advantages when you're out in the sticks having fun, but for overlanding in Africa you'd be looking for trouble i reckon
Thumbs Up
That being said, the only failures I have ever had on my 2 previous Td5's and now in the Puma have been mechanical ones.... --
Post #61974 3rd Mar 2011 11:04am
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
to dgardel:
Daniele, how did you disconnect EGR? Usig blank on engine instead of tube to EGR? May be you have photo?
Cheers Thumbs Up Puma 110
Post #62025 3rd Mar 2011 3:27pm
dgardel
Italy
Denis wrote:
to dgardel:
Cheers Thumbs Up
Simply take off the Electrical connector..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62026 3rd Mar 2011 3:30pm
Naks
Jah, but now the MIL light is on permanently. If something is going wrong with your engine, how would you know? Neutral --
Post #62027 3rd Mar 2011 3:31pm
dgardel
Italy
Actually, every month I check DTC status with my BAS Remap, but stay "on line" because Pete (Bellautoservices) is coming with a "definitive" solution w/o MIL on Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62029 3rd Mar 2011 3:50pm
Naks
Entreq also have one on the way apparently --
Post #62030 3rd Mar 2011 3:54pm
dgardel
Italy
Yes "we" know Whistle Thumbs Up
Asap news on entreq mods......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62059 3rd Mar 2011 6:21pm
dgardel
Italy
My goal is run BAS EGR SW killer with entreq mod without MIL ON
soon the results (positive I hope) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62062 3rd Mar 2011 6:30pm
ZeDefender
*deleted as I found the answer - cheers* Tell someone you love them today because life is short.
Post #144597 12th May 2012 8:07am
Page 2 of 3 <123>
