Home > Technical > Is it possible? (EGR disconnetted) |
Let the light ON and drive with a "clean" intake engine (like me, now my Defender have 61000km, 58000 with egr not connected......) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Mar 2011 9:25am |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 |
Ciao Daniele, what about fuel consumption with egr disconnected? Vinicio |
3rd Mar 2011 9:27am |
Here it's the fraud . |
3rd Mar 2011 9:35am |
not verified at the time, but I presume 2-3 mpg more... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Mar 2011 10:05am |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
[quote="mse life and death - you take the equipment required to resolve the problem...in an engine with electronics you just add some electronic bits, no different to throwing in a gasket etc.
[/quote] Mmm, dunno about this - there's a huge difference between "throwing in a gasket" and "throwing in a few modern electronic components". The complex electronics and engine management are the ONLY reasons why i wouldn't take my Defender up to Angola, Zambia, etc. Sure, easy countries like Botswana and Mozambique yes, but no further North than that. I understand and appreciate the advantages when you're out in the sticks having fun, but for overlanding in Africa you'd be looking for trouble i reckon..., and (for me) i'd like to explore the possibility of removing some of the very advanced electronics - Africa's a great place to explore (in a super reliable vehicle). Cheers www.ralton.co.za |
3rd Mar 2011 10:49am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
That being said, the only failures I have ever had on my 2 previous Td5's and now in the Puma have been mechanical ones.... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd Mar 2011 11:04am |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 |
to dgardel:
Daniele, how did you disconnect EGR? Usig blank on engine instead of tube to EGR? May be you have photo? Cheers Puma 110 |
3rd Mar 2011 3:27pm |
Simply take off the Electrical connector..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Mar 2011 3:30pm |
Jah, but now the MIL light is on permanently. If something is going wrong with your engine, how would you know? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd Mar 2011 3:31pm |
Actually, every month I check DTC status with my BAS Remap, but stay "on line" because Pete (Bellautoservices) is coming with a "definitive" solution w/o MIL on Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
3rd Mar 2011 3:50pm |
Entreq also have one on the way apparently -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd Mar 2011 3:54pm |
Yes "we" know Click image to enlarge Asap news on entreq mods...... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Mar 2011 6:21pm |
My goal is run BAS EGR SW killer with entreq mod without MIL ON
soon the results (positive I hope) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Mar 2011 6:30pm |
*deleted as I found the answer - cheers* Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
12th May 2012 8:07am |
