Home > Maintenance & Modifications > Door hinges greasable - finally
Page 1 of 5 12345>
ericvv
Anybody have something like this already installed? Aircraft aluminium, Eloxal treated, replacable HD SS bearing with grease channels, and last but not least a permanent attached grease nipple. German made, available from Offroad Monkeys as well as from Matzker, or in Switzerland from Rauh Engineering. Seems a pretty recent new product, found them at the LRoS 30 years Celebration event.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #640221 28th Jul 2017 6:01am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Neat !!
Post #640223 28th Jul 2017 6:32am
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Looks good......👌 πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #640224 28th Jul 2017 6:33am
m33ufo
Wales
Re: Door hinges greasable - finally
ericvv wrote:
German made, available from Offroad Monkeys....
Googled but couldn't find a link to off-road monkeys. Can you point me in the right direction?
They look cool but I'm guessing quite pricey? 110 DCPU
Mark
Post #640229 28th Jul 2017 7:16am
Here you go, 419 euros:
https://www.offroad-monkeys.de/produkte/ Darren
Post #640231 28th Jul 2017 7:37am
familymad
Great product 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #640232 28th Jul 2017 7:37am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
880 Euro's for a 4 door set + stainless bolts extra Shocked
https://www.matzker.de/Technik-Zubehoer/fu...:5499.html
Post #640233 28th Jul 2017 7:42am
m33ufo
Wales
Thumbs Up 110 DCPU
Mark
Post #640234 28th Jul 2017 7:47am
discomog
Yes definitely look good. One of the advantages of using the eloxal process is that it allows colours to be added to the electrolyte bath. It would be good if these hinges were available in various colours, either to contrast the vehicle body colour or indeed to match it. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #640236 28th Jul 2017 8:08am
ericvv
Black is good enough a match for my SVX's Santorini Black. How do I know? Whistle Yes, have a set already.
I was able to pay far less as they offered a nice discount at the recent LRoS 30 years Celebration event. When I saw them there I did not hesitate long. Can confirm that in the flesh they look as good as in the pictures. Thumbs Up
The two boxes with my 8 hinges have arrived, but will be installed early October by the Defender guru by excellence in Uhldingen-MΓΌhlhofen. A 500 km one way drive from here, but it means German quality installation and perfectly aligned doors. Won't be the only thing that will happen to the SVX in Germany that week, but more about that after its all done. It will include the 3rd and last leg of my air flow optimisation, the Airflow Kit II, which will complement the already installed intercooler and SS pipes from the same German supplier. Cool And then some.... Laughing
Post #640240 28th Jul 2017 8:34am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Eric, sounds like you should have brought a Unimog instead of the Defender? Laughing 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #640244 28th Jul 2017 8:56am
ericvv
Won't use stainless bolts in these new greasable alu hinges. Many here will know that I'm a strong believer in genuine mild bolts plus copious amounts of Weicon paste. Mild bolts on aluminium electro reaction remains milder than SS on Alu reaction. If such a genuine mild steel bolt would decide to start rusting, the Weicon paste means that at all times it will come out easy to allow replacement by a new one. Have a good supply of all of those genuine bolts, doubt I ever will have to use one though thanks to the Weicon protection. Time will tell.
Eric
P.S. this here is just for any Swiss members who might be interested in a set. As mentioned in my initial post, there is a Swiss distributor, Rauh Engineering, with competitive CHF prices for these German hinges. No hassle with expensive shipping from Germany and no import duties. Contact Markus Rauh at markus@rough-parts.com You never actually own a Defender. You merely look after it for the next generation.
Post #640248 28th Jul 2017 9:26am
hank
Really like these. The nicest (most OEM) looking hinges on the market I'd say.
Post #640252 28th Jul 2017 9:31am
integrale
New Zealand
The rear door hinges appear to be available in silver or black, but the "side" door hinges only in black. Is that correct, Eric? Thanks
Post #640256 28th Jul 2017 10:06am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Cheaper route... open door, drill 1.5 or 2mm hole in centre of the hinge and pump in grease with a chainsaw grease gun. You can feel the drill touch the hingepin.
Post #640262 28th Jul 2017 10:27am
Page 1 of 5 12345>
