Home > Technical > Windscreen Wipers a Little Slow to Get Going
Galyman
Scotland 2013 Defender 110 Puma 2.2 HT Aintree Green
Hi
The windscreen wipers on my 2012 Defender are very sluggish across the screen when first switched on and are a bit painful to watch. They tend to take a wee while to warm up to their normal speed. Just wondering if it is time for a new motor before they give up on me in the middle of a heavy downpour.
Any suggestions appreciated.
Post #639175 23rd Jul 2017 3:32pm
mk1collector
It's more likely to be the wheel boxes seizing up, you can pull the rubber boots of the wiper spindle under the wiper arm and shoot some wd40 or similar down the spindle while there running to prolong life for a while. Ray
My build thread
Post #639176 23rd Jul 2017 3:35pm
Galyman
Will give them a wee spray and see how that goes.
Post #639181 23rd Jul 2017 3:57pm
degi80
Malta 2007 Defender 90 Puma 2.4 PU Chawton White
worked wonders for me!! Thanks
Post #764722 21st Mar 2019 8:11pm
Once its freed up a bit use some longer lasting lube like 3in1 on it too, as the WD40 will dry out in a short while.
I had one spindle seize completely last year, and the spring to early summer transition is the most likely as it drys out and seizes often with rusty dust. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #764725 21st Mar 2019 8:21pm
oneten110
Aerosol silicon grease It is not a Defender, it is a One_Ten
Post #765201 24th Mar 2019 5:58pm
