![]() | Home > Technical > Windscreen Wipers a Little Slow to Get Going |
It's more likely to be the wheel boxes seizing up, you can pull the rubber boots of the wiper spindle under the wiper arm and shoot some wd40 or similar down the spindle while there running to prolong life for a while. Ray
Galyman Member Since: 20 Jan 2016 Location: Scottish Borders Posts: 92 ![]() ![]() ![]() |
Will give them a wee spray and see how that goes. |
degi80 Member Since: 24 Apr 2011 Location: MT Posts: 24 ![]() ![]() ![]() |
worked wonders for me!! Thanks |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20627 ![]() ![]() |
Once its freed up a bit use some longer lasting lube like 3in1 on it too, as the WD40 will dry out in a short while.
I had one spindle seize completely last year, and the spring to early summer transition is the most likely as it drys out and seizes often with rusty dust. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Aerosol silicon grease It is not a Defender, it is a One_Ten
