Home > Maintenance & Modifications > ** Update = Sorted ** Spacers on and now wheel wobble.
Page 3 of 4 <1234>
JOW240725
Scott, the description of your 'wobble' is very different to the one I experienced, so unfortunately does sound more than balancing to me. Hope you get it sorted soon. I have no concerns (nor did insurance company) running high quality hub centric spacers Thumbs Up Improvement in turning circle is worth it alone! James
Instagram @suffolk_rovers
Post #631572 15th Jun 2017 12:26pm
rallysteve
Sorry, the sweeping claims of spacers 'overloading' the hubs is b******s. Nothing but an internet myth that circulates around car forums.
Fitting spacers does indeed increase the bending moment at the wheel bearing but is identical to fitting the same offset of wheel.
Unless you are fitting ridiculous length spacers the worst damage would be increased wear to the wheel bearings. Again though, this will be no different to the fitting wheels of equivalent offset and should not be an issue unless your wheel bearings are already ruined or wrongly setup.
Broken spacers/wheels falling off with spacers is a product of misuse (i.e. overtightenend or undertightened nuts) or poor quality (probably made in china spacers).
Bulldog spacers I believe have a good reputation at least. I used Rakeway ones which are also highly regarded.
Post #631580 15th Jun 2017 1:03pm
Lightningtweeds wrote:
Spacers overload the hubs and are only for massaging self-esteem.
Rolling with laughter
Am I allowed to say "cobblers!" on a family forum?
Post #631599 15th Jun 2017 2:45pm
Stacey007
So What do people think may cure the wobble.
1) Leave them off..
2) Clean the hub / wheel / try again (they both looked pretty good to me)
3) Panhard Bushes on the front steering arm thingy....
4) Uprated steering damper.
Should something above help? (option 1 is current being Thumbs Up tested and its fine) but I would like the on.
Post #631603 15th Jun 2017 3:05pm
mk1collector
mk1collector wrote:
Try the rear spacers on the front and see if you still have a wobble.
 Ray
My build thread
Post #631607 15th Jun 2017 3:15pm
mk1collector
Well what a lot of drivel! Ray
My build thread
Post #631608 15th Jun 2017 3:17pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Shouldn't need an uprated one. If your current one is knackered a new standard one will feel much better. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #631610 15th Jun 2017 3:21pm
JOW240725
Give up on the Puma and just use the Series, wobbles will be the least of your worries! Rolling with laughter Rolling with laughter James
Post #631613 15th Jun 2017 3:28pm
CarlinAbz
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
I put 30mm spacers on, changed tyres to 265 and had engine remap all when the vehicle was less than a month old... 20,000 miles later and no issues. There are always doom merchants that tell you horror stories of insurance, warranty and technical woes. Ignore, enjoy and let fate take you on your journey.....
Post #631618 15th Jun 2017 3:37pm
Thon
Post #631622 15th Jun 2017 3:58pm
JOW240725
I quite like a massage Whistle James
Post #631623 15th Jun 2017 4:00pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I had a wheel wobble. Replaced my steering damper with a bilstien. The factory one was completely shot! The new one felt better, you could feel it doing its job but the wobble was still there.
mine turned out to be a steering swivel bearing failure, it could have been disturbed during some other work? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #631624 15th Jun 2017 4:05pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
The further the rim is from the bearings will increase the leverage/bending/throw, maybe not by a huge amount but the metallurgists on here may know different.
Post #631628 15th Jun 2017 4:17pm
rallysteve
Exactly my point above.
No different to modifying the offset of the wheel. Nothing to do with metallurgy, just simple engineering. 02' 110 TD5 Double Cab Rebuild Thread
Post #631631 15th Jun 2017 4:38pm
Stacey007
James,
I like the Use the Series option Smile Turn the wheel half a turn and nothing happens in that Thumbs Up it bounces and wobbles around Shocked
Trying the rears on the front is maybe my first option? Thanks
Then a steering damper?
Post #631649 15th Jun 2017 5:35pm
Page 3 of 4 <1234>
