Home > Off Topic > My RRC project |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4790 |
There are already 4 cooling fans so I think that's probably enough! The air con system fans turn on for extra cooling and there are twin Kenlowe fans which are in place of the standard viscous unit.
All of these work fine, it's just the ECU that isn't (or wasn't) seeing the correct temperature. It's all ok now, idling at about 700rpm 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Jun 2018 8:46pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Does that mean MOT time Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
4th Jun 2018 9:01pm |
Not quite yet, fingers crossed for the end of this week 2002 90 Td5 Station Wagon
4th Jun 2018 9:13pm |
Will keep them crossed for you Clayton.
4th Jun 2018 9:15pm |
5th Jun 2018 7:08am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2225 |
Great work as usual Grafty, good luck with MOT
Passed my MOT last week could do with a new set of rear window rubbers tho Click image to enlarge |
5th Jun 2018 8:08pm |
Cheers Keith. If I can clear the ABS fault in the next couple of days then I'll be getting an MOT very soon indeed!
It can't be long until someone comes up with new rear window rubbers, I think every 4 door classic needs them don't they?! Yours looks lovely. I hope mine will look that smart when it's done 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
5th Jun 2018 10:00pm |
Ok, I'm getting towards the end of my tether with the ABS now!
I have solved the one persistent code I was getting which was 2-8 valve solenoid open circuit. This turned out to be a faulty relay which had a healthy click but wasn't making contact. Anyway with this sorted you can drive around and get no fault codes but the light isn't going out. The light relay is ok as I have swapped that for a few different relays with non of them making a difference. It must be the ECU leaving the light on as when you put a jumper wire in the diagnostic port it begins to flash but no giving any codes. This rules out a wiring fault causing the light to come on. The diagnostic procedure involves removing the ABS light relay but I don't have to do this to make the light flash it's blink codes. Does anyone have any ideas? No garages around by me are able to interrogate the ECU as it's such an old sytem This is the only thing now stopping me getting an MOT! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
10th Jun 2018 1:35pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 |
Are you able to borrow an ECU and swap that out to see if it solves the problem?
10th Jun 2018 1:52pm |
Forgot to mention that. The ECU from the donor range rover behaves exactly the same 2002 90 Td5 Station Wagon
10th Jun 2018 2:17pm |
It might be worth trying a third ECU if you have access to one. You could spend a lot of time chasing an error in a place it isn’t going to be found!
I hope you get it sorted out quickly. |
10th Jun 2018 6:37pm |
The thing that makes me doubt it's the ECU is that both vehicles had fully functional ABS before the rebuild. But, as you say, trying a third ECU would be well worth a try.
Anyone close to Woolacombe with an ABS equipped Range Rover Classic? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
10th Jun 2018 7:27pm |
Sad news you cant get to the bottom of this problem grafty
What year did they start putting ABS and ECU's on the RRC ? Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
12th Jun 2018 8:01pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
just take the bulb out that's it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
13th Jun 2018 4:59am |
