Home > Off Topic > My RRC project
Page 23 of 53 <123 ... 222324 ... 515253>
Procta
grafty99 wrote:
I haven't yet. That's this weekend's task. I have bought a cable and installed Rovergauge on my laptop so can now interrogate the ECU.
This revealed a faulty coolant temperature sensor (ECU one, dash one still working) which probably explained the slightly raised idle speed. The ECU didn't see the engine getting any warmer.
I'm going to tackle the ABS warning light and then book an MOT!
Ah if its the cooling sensor I am thinking about on rover cars, that is well known to cause trouble at the best of times. For god sake don't buy an after market one! I ended up replacing those practically every 6 months! What rover did with the later stuff, was if that sensor fails, the ECU would kick the fan on. I had two fan systems, one with the rad switch system and the other with the ECU with this said sensor. So if the sensor failed, I could hear it kick that fan on. If I were you grafty I would look at putting another fan system in there, as a back up. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #710708 4th Jun 2018 11:21am
grafty99
There are already 4 cooling fans so I think that's probably enough! The air con system fans turn on for extra cooling and there are twin Kenlowe fans which are in place of the standard viscous unit.
All of these work fine, it's just the ECU that isn't (or wasn't) seeing the correct temperature. It's all ok now, idling at about 700rpm Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #710811 4th Jun 2018 8:46pm
L110CDL
Does that mean MOT time Whistle Clayton.
Keeper.
Post #710816 4th Jun 2018 9:01pm
grafty99
Not quite yet, fingers crossed for the end of this week Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #710818 4th Jun 2018 9:13pm
L110CDL
Will keep them crossed for you Wink Clayton.
Keeper.
Post #710819 4th Jun 2018 9:15pm
grafty99
1990 Vogue SE
Post #710844 5th Jun 2018 7:08am
keith
Great work as usual Grafty, good luck with MOT
Passed my MOT last week could do with a new set of rear window rubbers tho Rolling Eyes
Post #710986 5th Jun 2018 8:08pm
grafty99
Cheers Keith. If I can clear the ABS fault in the next couple of days then I'll be getting an MOT very soon indeed!
It can't be long until someone comes up with new rear window rubbers, I think every 4 door classic needs them don't they?! Laughing
Yours looks lovely. I hope mine will look that smart when it's done Bow down 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #711021 5th Jun 2018 10:00pm
grafty99
Ok, I'm getting towards the end of my tether with the ABS now!
I have solved the one persistent code I was getting which was 2-8 valve solenoid open circuit. This turned out to be a faulty relay which had a healthy click but wasn't making contact.
Anyway with this sorted you can drive around and get no fault codes but the light isn't going out. The light relay is ok as I have swapped that for a few different relays with non of them making a difference.
It must be the ECU leaving the light on as when you put a jumper wire in the diagnostic port it begins to flash but no giving any codes. This rules out a wiring fault causing the light to come on.
The diagnostic procedure involves removing the ABS light relay but I don't have to do this to make the light flash it's blink codes.
Does anyone have any ideas? No garages around by me are able to interrogate the ECU as it's such an old sytem Big Cry
This is the only thing now stopping me getting an MOT! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #711723 10th Jun 2018 1:35pm
Huttopia
Are you able to borrow an ECU and swap that out to see if it solves the problem?
Post #711725 10th Jun 2018 1:52pm
grafty99
Forgot to mention that. The ECU from the donor range rover behaves exactly the same Sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #711728 10th Jun 2018 2:17pm
Huttopia
It might be worth trying a third ECU if you have access to one. You could spend a lot of time chasing an error in a place it isn’t going to be found!
I hope you get it sorted out quickly.
Post #711770 10th Jun 2018 6:37pm
grafty99
The thing that makes me doubt it's the ECU is that both vehicles had fully functional ABS before the rebuild. But, as you say, trying a third ECU would be well worth a try.
Anyone close to Woolacombe with an ABS equipped Range Rover Classic? Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #711776 10th Jun 2018 7:27pm
L110CDL
Sad news you cant get to the bottom of this problem grafty Sad
What year did they start putting ABS and ECU's on the RRC ? Whistle Clayton.
Keeper.
Post #712103 12th Jun 2018 8:01pm
Procta
just take the bulb out that's it Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #712147 13th Jun 2018 4:59am
