- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Lorryman100
![](templates/vbnew/images/spacer.gif)
I have the scangauge and the nanocom, and I have found that the scangauge doesn't read any codes other than ones that kick the MIL on. There are definitely fault codes stored in the ecu on my landy which the nanocom reads but the scangauge doesn't. On the scangauge website there is a list of DTC's under the ford tab which is tiny in comparison to the list dgardel has on here.
HTH Brian.
1st Feb 2011 12:38pm |
Lorryman100
The only one I have had experience off is, "P1169 Fuel rail pressure sensor in range but high". Which kicked on the MIL and limp home mode.
2nd Feb 2011 11:28am |
