Home > Technical > Scanguage fault finding.
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Will the Scanguage II read and clear most fault codes on the Puma.I don't have TC and ABS so I don't want to go down the Nanocom road if I do not have to.I have read that it needs the MIL light to activate.Thanks Puma 110 SW
90 V8 SOFT TOP
Post #55999 1st Feb 2011 11:16am
Lorryman100
I have the scangauge and the nanocom, and I have found that the scangauge doesn't read any codes other than ones that kick the MIL on. There are definitely fault codes stored in the ecu on my landy which the nanocom reads but the scangauge doesn't. On the scangauge website there is a list of DTC's under the ford tab which is tiny in comparison to the list dgardel has on here.
HTH Brian.
Post #56012 1st Feb 2011 1:38pm
LESVOSD110
Do you know which ones activate MIL light? Puma 110 SW
90 V8 SOFT TOP
Post #56174 2nd Feb 2011 10:36am
Lorryman100
The only one I have had experience off is, "P1169 Fuel rail pressure sensor in range but high". Which kicked on the MIL and limp home mode.
Post #56198 2nd Feb 2011 12:28pm
