Home > Technical > Scanguage fault finding. |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
Will the Scanguage II read and clear most fault codes on the Puma.I don't have TC and ABS so I don't want to go down the Nanocom road if I do not have to.I have read that it needs the MIL light to activate.Thanks Puma 110 SW
90 V8 SOFT TOP |
1st Feb 2011 10:16am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I have the scangauge and the nanocom, and I have found that the scangauge doesn't read any codes other than ones that kick the MIL on. There are definitely fault codes stored in the ecu on my landy which the nanocom reads but the scangauge doesn't. On the scangauge website there is a list of DTC's under the ford tab which is tiny in comparison to the list dgardel has on here.
HTH Brian. |
1st Feb 2011 12:38pm |
Do you know which ones activate MIL light? Puma 110 SW
90 V8 SOFT TOP |
2nd Feb 2011 9:36am |
