Home > Wheels & Tyres > Spare tire
Page 3 of 3 <123
Tombte
Spain 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Door vibrates
I notice that what vibrates is the door panel not the wheel it self. I have a svx wheels with mantec carrier. I couldnt avoid the vibration because what vibrates is the door panel as the door is shut.
Post #69083 30th Apr 2011 10:55am
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Added the washers and it for the most part fixed the issue. 4 washers on top and 5 on each lower stud.
Thanks for advice.
Post #69677 4th May 2011 8:03pm
BigMike
why not 5 all round?
Post #69769 5th May 2011 12:28pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
I've also a 265 18incher and had the same problem with the rear wiper.
Problem was solved by putting some shock absorber washers between it. You just need to adjust to hole to the correct diameter, works perfect.
Post #84718 16th Aug 2011 6:24pm
Page 3 of 3 <123
