Home > Wheels & Tyres > Spare tire |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
Added the washers and it for the most part fixed the issue. 4 washers on top and 5 on each lower stud.
Thanks for advice. |
4th May 2011 7:03pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
why not 5 all round?
5th May 2011 11:28am |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 111 |
I've also a 265 18incher and had the same problem with the rear wiper.
Problem was solved by putting some shock absorber washers between it. You just need to adjust to hole to the correct diameter, works perfect. |
16th Aug 2011 5:24pm |
