Door vibrates
I notice that what vibrates is the door panel not the wheel it self. I have a svx wheels with mantec carrier. I couldnt avoid the vibration because what vibrates is the door panel as the door is shut.
30th Apr 2011 9:55am
defender75
Added the washers and it for the most part fixed the issue. 4 washers on top and 5 on each lower stud.
Thanks for advice.
4th May 2011 7:03pm
BigMike
why not 5 all round?
5th May 2011 11:28am
vogue se
I've also a 265 18incher and had the same problem with the rear wiper.
Problem was solved by putting some shock absorber washers between it. You just need to adjust to hole to the correct diameter, works perfect.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
