![]() | Home > Maintenance & Modifications > Strange LED's |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20638 ![]() ![]() |
Check the earth, especially main earth straps.
A loose one can cause all sorts of odd issues. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
Is the side indicator in the left wing also LED or is it incandescent? If the latter, and it failed, the resistance is wrong for the relay to operate correctly. Could also be an earthing issue there (at the left side indicator in the wing).
Don't ask how I know... ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
I would say earth - when the light board is plugged in it earths the indicators via the earth in the trailer socket thus full current can travel through the light units giving full brightness
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Check earth points on the bulkhead as I think that is where the main lighting loom earths to the body
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
Many thanks for your input, i have already checked that as i thought about it as the side ones are NOT led's and it is working 100% ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Been thinking its an earth problem but didnt know were the earths were ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I assume you are using the Wipac LED Relay and not a standard one?
I have the RDX one and used to run for a time incandescent side repeaters and LED indicators and all was fine. My bet is on an earth LED's are more sensitive to earth issues. On a Puma there is the earth strap on the transferbox, there might be one on yours too? When I had an issue with that one being loose I had brake lights light up when you indicate. Dash lights flashing, all four indicators on the next and so on. Cleaned and tightened the earth strap and all was good. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Yes got the wipac LED relay on and i will check the earth strap on the transfer box tomorrow at work, many thanks Steve
You might have one there anyway, if not you'll soon see them underneath direct to chassis.
Any chassis ones be careful not to at all over tighten, they are good at shearing! TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Ok will remember that, thanks
Bulkhead earths are near the heater box and brake servo I seem to remember.
Transfer box earth strap is also a good shout ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Front arch outriggers are another area. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Tow electrics corroded or wet/muddy? Ray
Just to update you all, yesterday had the afternoon off due to the heavy rain, so went up to the store, parked the landy in the dry and set about to find the problem, unscrewed the indicator, cleaned contacts and while disconnected i turned on the indicator stalk to see if it would make any difference, but it did not, this was the nearside back after connecting back together i sprayed some GT85 in to help repel the water, then went on to do the same to the other 3 indicators but all the same, no difference, but i did not use GT85 on them because they were all bone dry
![]() ![]() ![]() ![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
