Home > Maintenance & Modifications > Strange LED's |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20377 |
Check the earth, especially main earth straps.
A loose one can cause all sorts of odd issues. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jan 2017 9:11pm |
Is the side indicator in the left wing also LED or is it incandescent? If the latter, and it failed, the resistance is wrong for the relay to operate correctly. Could also be an earthing issue there (at the left side indicator in the wing).
Don't ask how I know... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Jan 2017 9:13pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
I would say earth - when the light board is plugged in it earths the indicators via the earth in the trailer socket thus full current can travel through the light units giving full brightness 2002 90 Td5 Station Wagon
30th Jan 2017 9:43pm |
Check earth points on the bulkhead as I think that is where the main lighting loom earths to the body 2002 90 Td5 Station Wagon
30th Jan 2017 9:45pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10756 |
Many thanks for your input, i have already checked that as i thought about it as the side ones are NOT led's and it is working 100% 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
30th Jan 2017 10:11pm |
Been thinking its an earth problem but didnt know were the earths were Could you let me know were they are on the bulkhead please 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
30th Jan 2017 10:13pm |
I assume you are using the Wipac LED Relay and not a standard one?
I have the RDX one and used to run for a time incandescent side repeaters and LED indicators and all was fine. My bet is on an earth LED's are more sensitive to earth issues. On a Puma there is the earth strap on the transferbox, there might be one on yours too? When I had an issue with that one being loose I had brake lights light up when you indicate. Dash lights flashing, all four indicators on the next and so on. Cleaned and tightened the earth strap and all was good. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jan 2017 10:16pm |
Yes got the wipac LED relay on and i will check the earth strap on the transfer box tomorrow at work, many thanks Steve 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
30th Jan 2017 10:22pm |
You might have one there anyway, if not you'll soon see them underneath direct to chassis.
Any chassis ones be careful not to at all over tighten, they are good at shearing! $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Jan 2017 10:26pm |
Ok will remember that, thanks 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
30th Jan 2017 10:36pm |
Bulkhead earths are near the heater box and brake servo I seem to remember.
Transfer box earth strap is also a good shout 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
30th Jan 2017 10:37pm |
Front arch outriggers are another area. $W33T $0U7H3RN $UG4R
30th Jan 2017 10:42pm |
Tow electrics corroded or wet/muddy? Ray
Just to update you all, yesterday had the afternoon off due to the heavy rain, so went up to the store, parked the landy in the dry and set about to find the problem, unscrewed the indicator, cleaned contacts and while disconnected i turned on the indicator stalk to see if it would make any difference, but it did not, this was the nearside back after connecting back together i sprayed some GT85 in to help repel the water, then went on to do the same to the other 3 indicators but all the same, no difference, but i did not use GT85 on them because they were all bone dry so still not working properly i switched on the hazard switch and they worked ok, but i noticed the nearside back indicator was NOT working at all so being there is not much room there, took it all apart and cleaned it up again, then connected it up again and then when my hand was up behind the thick plastic shield there is a metal type of shelf as you can see from the outside once the indicator unit is unscrewed and put the connected unit up there out of the way from all of the water, mud etc and then pushed the plastic shield back against the metal shelf to hold the connector up there and it has stayed in place So checked the indicator was working again and was so the big moment again and try the nearside indicator's, expecting that nothing has changed and to my surprise it is all working as normal now, so hoping it will last 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Feb 2017 9:45pm |
