Home > Maintenance & Modifications > Strange LED's
L110CDL
Strange LED's
Hi all, hope you can help in some way....
Well it started yesterday when i was driving back to home when i put my left indicator on and the bulb on the dash was alot dimmer than it should be, so i put the right indicator on and that worked fine as normal, so i assumed that the left indicator was working ok, but when i got home and checked them all was not ok Big Cry You put the left indicator on and all 4 indicators start flashing and they are dimmer than normal, so i thought it must be the relay, so today i bought a relay (i have wipac led's)and put it in and its still the same, so got to thinking and then plugged a light board in, (thinking the socket has had it) and it was very strange that the LED's worked normal again and the light board has bulbs in,i have had these on between 2-3 years with no proplems at all, so any thoughts are much appreciated, many thanks 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #597796 30th Jan 2017 8:56pm
Check the earth, especially main earth straps.
A loose one can cause all sorts of odd issues. $W33T $0U7H3RN $UG4R
Post #597807 30th Jan 2017 9:11pm
VeeTee
Netherlands
Is the side indicator in the left wing also LED or is it incandescent? If the latter, and it failed, the resistance is wrong for the relay to operate correctly. Could also be an earthing issue there (at the left side indicator in the wing).
Don't ask how I know... Wink Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #597808 30th Jan 2017 9:13pm
grafty99
I would say earth - when the light board is plugged in it earths the indicators via the earth in the trailer socket thus full current can travel through the light units giving full brightness Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #597834 30th Jan 2017 9:43pm
grafty99
Check earth points on the bulkhead as I think that is where the main lighting loom earths to the body Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #597836 30th Jan 2017 9:45pm
L110CDL
Many thanks for your input, i have already checked that as i thought about it as the side ones are NOT led's and it is working 100% Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #597876 30th Jan 2017 10:11pm
L110CDL
Been thinking its an earth problem but didnt know were the earths were Rolling Eyes Could you let me know were they are on the bulkhead please Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #597878 30th Jan 2017 10:13pm
I assume you are using the Wipac LED Relay and not a standard one?
I have the RDX one and used to run for a time incandescent side repeaters and LED indicators and all was fine.
My bet is on an earth LED's are more sensitive to earth issues.
On a Puma there is the earth strap on the transferbox, there might be one on yours too?
When I had an issue with that one being loose I had brake lights light up when you indicate.
Dash lights flashing, all four indicators on the next and so on.
Cleaned and tightened the earth strap and all was good. $W33T $0U7H3RN $UG4R
Post #597883 30th Jan 2017 10:16pm
L110CDL
Yes got the wipac LED relay on and i will check the earth strap on the transfer box tomorrow at work, many thanks Steve Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #597894 30th Jan 2017 10:22pm
You might have one there anyway, if not you'll soon see them underneath direct to chassis.
Any chassis ones be careful not to at all over tighten, they are good at shearing! $W33T $0U7H3RN $UG4R
Post #597898 30th Jan 2017 10:26pm
L110CDL
Ok will remember that, thanks Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #597903 30th Jan 2017 10:36pm
grafty99
Bulkhead earths are near the heater box and brake servo I seem to remember.
Transfer box earth strap is also a good shout Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #597905 30th Jan 2017 10:37pm
Front arch outriggers are another area. $W33T $0U7H3RN $UG4R
Post #597909 30th Jan 2017 10:42pm
mk1collector
Tow electrics corroded or wet/muddy? Ray
My build thread
Post #597910 30th Jan 2017 10:42pm
L110CDL
Just to update you all, yesterday had the afternoon off due to the heavy rain, so went up to the store, parked the landy in the dry and set about to find the problem, unscrewed the indicator, cleaned contacts and while disconnected i turned on the indicator stalk to see if it would make any difference, but it did not, this was the nearside back after connecting back together i sprayed some GT85 in to help repel the water, then went on to do the same to the other 3 indicators but all the same, no difference, but i did not use GT85 on them because they were all bone dry Very Happy so still not working properly i switched on the hazard switch and they worked ok, but i noticed the nearside back indicator was NOT working at all Rolling Eyes so being there is not much room there, took it all apart and cleaned it up again, then connected it up again and then when my hand was up behind the thick plastic shield there is a metal type of shelf as you can see from the outside once the indicator unit is unscrewed and put the connected unit up there out of the way from all of the water, mud etc and then pushed the plastic shield back against the metal shelf to hold the connector up there and it has stayed in place Very Happy So checked the indicator was working again and was Thumbs Up so the big moment again and try the nearside indicator's, expecting that nothing has changed and to my surprise Surprised it is all working as normal now, so hoping it will last Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #598416 1st Feb 2017 9:45pm
