![]() | Home > Maintenance & Modifications > Electrics advice - extra fusebox + |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1051 ![]() ![]() ![]() |
I currently have a 2nd tracker wired directly to the battery. I'd like to fit some extra USB sockets to the centre console. All nice and easy if I just wire to the battery again, but well aware that's a but crap. Especially if something is left plugged in!
I'd like to be able to fit an extra fuse box, probably under the cubby or in the battery compartment. It would only need space for 4 or 5 fuses, but would also like some sort of relay so that it's only live when the engine's running. All nice and easy from an electrical perspective, but does anyone know of such a thing 'off the shelf'? I'm comfortable doing electrical work, it's just caution about flat batteries and being clueless about every other part of a Land Rover. |
Thanks for the quick reply.
The tracker has a battery, so shouldn't need a permanent live. To be honest, it's a sacrificial tracker that's easy to find to divert attention from 'other security features' ![]() Is it possible to just have a relay that switches on at 14V so that it automatically comes on when the battery is charging? I'm sure I've seen dual battery setups that work like that. |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
You're now looking at the dual battery charging, I'm sure there is a relay that you could use, i'll have to leave that to the experts though
Red8eard Member Since: 21 Oct 2016 Location: UK Posts: 69 ![]() ![]() |
If you look on ebay you can find fuse boxs that take 1 feed and bleed it off into many fused feeds, if your total usage is under 30A then get a std relay and wire it from the battery to the fusebox and wire the trigger to a switched live on the vehicle then that entire fusebox is wired to a switched live.
i have 2 fuseboxs in mine constant live through a midi fuse and a switched live through a relay to run accessories. Bit hard to explain but theres pleanty of info on the web and its easily doable in the defender. -Ged |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello AMBxx
I fitted one of the Blue Sea Fuse Boxes, (from Mudstuff) well made and for a simple few extra 'properly' wired accessories OK http://www.mudstuff.co.uk/blue-sea-fuse-block.html ![]() https://www.defender2.net/forum/topic83242.html |
That looks really neat and very simple to wire in. Downside being that there's no way to turn it off when the ignition's off. Might have to live without that bit.
thanks. |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
+1 for the Blue Sea Fuse Boxes...
But why stop with 1? ![]() ![]() Click image to enlarge |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
...just need a couple of "Trans-warp-conduits" and "Inter-phasing-alignment-rectifiers" in there ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Why do electrics scare me.... oh I remember
![]() ![]() ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Big thank you to all for help on this. I finally took the plunge today.
I bought one of these: https://www.mobilecentre.co.uk/index.php?m...ts_id=1148 and one of these nifty gadgets to only switch on when the engine is running: http://www.mobilecentre.co.uk/index.php?ma...tfvtn2grm4 I wanted to keep the area around the battery clear for the other rubbish I keep in there, so routed a wire from the battery to the compartment underneath the driver's seat. I realise I could have cut into an existing wire, but was concerened about warranty issues (and breaking things). Now I have a USB socket in the back of my mudstuff safe and the tracker is now properly wired into the new fusebox and hidden way properly. Earthing went better than expected - for the USB, turned out that the screws bolting the safe in were earthed. For the rest, I used one of the bolts under the driver's seat. Only mistake I made was not realising the voltage switching gizmo needed to be earthed. While I had my tools out, I finally got round to fitting the 2nd row door extenders so easier to get big stuff into the back seat. I bought them 18 months ago, so about time! Thanks again, I now feel much more comfortable in carrying out other electrical work (I have 2 spare fuses to do something with). |
I would not advise using that voltage based relay, it will fail and leave you with a dead battery because of how damp defenders can get..
Instead you should use a normal relay and activate it from an ignition controlled positive feed, like the cigarette socket. ![]() |
Hmm, didn't know about that. There's not much load on it though and it's in a sealed bag with the rest of the fuses. My tracker monitors voltage, so I should see if there's a problem.
Thanks for the advice though. |
