Home > Maintenance & Modifications > Electrics advice - extra fusebox +
AMBxx
I currently have a 2nd tracker wired directly to the battery. I'd like to fit some extra USB sockets to the centre console. All nice and easy if I just wire to the battery again, but well aware that's a but crap. Especially if something is left plugged in!
I'd like to be able to fit an extra fuse box, probably under the cubby or in the battery compartment. It would only need space for 4 or 5 fuses, but would also like some sort of relay so that it's only live when the engine's running.
All nice and easy from an electrical perspective, but does anyone know of such a thing 'off the shelf'? I'm comfortable doing electrical work, it's just caution about flat batteries and being clueless about every other part of a Land Rover.
Post #595812 24th Jan 2017 8:33am
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I put a 2nd fuse box in battery compartment, then ran a 7 core trailer cable to the dashboard. Each outlet of the fusebox (I think mines a 12 way) has a separate colour wire going to dash to feed auxiliaries, when i want one of the wires live I just put the corresponding fuse in.
You could intercept the +ve from the battery to aux fusebox with a relay that only operates when you turn the ignition on, Tee into a switched live to operate the relay.
If you are wiring up the tracker, this will need to be a permanent live though wont it?
Post #595813 24th Jan 2017 8:40am
AMBxx
Thanks for the quick reply.
The tracker has a battery, so shouldn't need a permanent live. To be honest, it's a sacrificial tracker that's easy to find to divert attention from 'other security features' Wink
Is it possible to just have a relay that switches on at 14V so that it automatically comes on when the battery is charging? I'm sure I've seen dual battery setups that work like that.
Post #595816 24th Jan 2017 8:42am
Buz
You're now looking at the dual battery charging, I'm sure there is a relay that you could use, i'll have to leave that to the experts though Wink
Post #595820 24th Jan 2017 9:08am
Red8eard
2003 Defender 130 Other HCPU Chawton White
If you look on ebay you can find fuse boxs that take 1 feed and bleed it off into many fused feeds, if your total usage is under 30A then get a std relay and wire it from the battery to the fusebox and wire the trigger to a switched live on the vehicle then that entire fusebox is wired to a switched live.
i have 2 fuseboxs in mine constant live through a midi fuse and a switched live through a relay to run accessories.
Bit hard to explain but theres pleanty of info on the web and its easily doable in the defender.
-Ged
Post #595838 24th Jan 2017 10:02am
X4SKP
Hello AMBxx
I fitted one of the Blue Sea Fuse Boxes, (from Mudstuff) well made
and for a simple few extra 'properly' wired accessories OK
http://www.mudstuff.co.uk/blue-sea-fuse-block.html
 SKIP
Post #595861 24th Jan 2017 12:05pm
AMBxx
That looks really neat and very simple to wire in. Downside being that there's no way to turn it off when the ignition's off. Might have to live without that bit.
thanks.
Post #595889 24th Jan 2017 1:50pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
+1 for the Blue Sea Fuse Boxes...
But why stop with 1? Laughing
Post #595897 24th Jan 2017 2:03pm
grafty99
Shocked Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #595916 24th Jan 2017 3:39pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
...just need a couple of "Trans-warp-conduits" and "Inter-phasing-alignment-rectifiers"
in there Rolling with laughter 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
Post #595923 24th Jan 2017 4:01pm
X4SKP
Post #595950 24th Jan 2017 5:42pm
JOW240725
Why do electrics scare me.... oh I remember Big Cry Big Cry Big Cry
 James
Instagram @suffolk_rovers
Post #595953 24th Jan 2017 5:47pm
AMBxx
Big thank you to all for help on this. I finally took the plunge today.
I bought one of these: https://www.mobilecentre.co.uk/index.php?m...ts_id=1148
and one of these nifty gadgets to only switch on when the engine is running: http://www.mobilecentre.co.uk/index.php?ma...tfvtn2grm4
I wanted to keep the area around the battery clear for the other rubbish I keep in there, so routed a wire from the battery to the compartment underneath the driver's seat. I realise I could have cut into an existing wire, but was concerened about warranty issues (and breaking things).
Now I have a USB socket in the back of my mudstuff safe and the tracker is now properly wired into the new fusebox and hidden way properly.
Earthing went better than expected - for the USB, turned out that the screws bolting the safe in were earthed. For the rest, I used one of the bolts under the driver's seat.
Only mistake I made was not realising the voltage switching gizmo needed to be earthed.
While I had my tools out, I finally got round to fitting the 2nd row door extenders so easier to get big stuff into the back seat. I bought them 18 months ago, so about time!
Thanks again, I now feel much more comfortable in carrying out other electrical work (I have 2 spare fuses to do something with).
Post #598849 3rd Feb 2017 4:10pm
mrd1990
I would not advise using that voltage based relay, it will fail and leave you with a dead battery because of how damp defenders can get..
Instead you should use a normal relay and activate it from an ignition controlled positive feed, like the cigarette socket. Thumbs Up
Post #599877 7th Feb 2017 4:21pm
AMBxx
Hmm, didn't know about that. There's not much load on it though and it's in a sealed bag with the rest of the fuses. My tracker monitors voltage, so I should see if there's a problem.
Thanks for the advice though.
Post #599879 7th Feb 2017 4:33pm
