Home > Puma (Tdci) > CAUTION! PUMA & fording
Page 3 of 7 <1234567>
Glynparry25
fordy103 wrote:
also, got snotty remarks at james edwards, when i turned up in mine to complain about a rattly dashboard, and the service guy kept questioning me why i had a snorkel etc etc. On another note, has anybody found a way of making the ECU watertight in a puma yet? sealed both my seat boxes today when i fitted my winch, but wasnt really liking the ecu placement
I wouldn't worry too much about the ECU, I have had mine soaaked with spray from hours and hours of driving across Europe the motorway in the rain and floods and never had any problems.
Glyn Sheep
Post #54593 22nd Jan 2011 6:58pm
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
just to clarify the ecu is mounted at the top of the bulkhead behind the engine?
Post #54595 22nd Jan 2011 6:59pm
Glynparry25
YEP Thumbs Up
Glyn Sheep
Post #54597 22nd Jan 2011 7:01pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
On a personal note when you do any decent wading there is a small chance you may get in a few inches deeper than you expect (having walked the route with a stick first of course Laughing ) and for the sake of a couple of quid of plastic pipe which, if you have gone to the trouble of paying over £100 for a snorkel, is easily run up the thing - gives you peace of mind. You can never really be sure where the bow wave is going in the engine compartment, and you'll never know if you taken water into the oil - until you come to drain it in 20 - 30,000Km
Couple of thoughts - check air tightness of snorkel by covering it up and stalling the engine, and; if you have ARB lockers with externally fitted compressor then you may want to fit a pipe to the compressor inlet too.
Post #55011 25th Jan 2011 8:28pm
Naks
Difficult on a Puma, no?
Post #55012 25th Jan 2011 8:32pm
nakatanenga
Germany
On a Td5 you can stall the engine by putting the hand on the snorkel, done this a lot of times while testing airtightness on fresh installed snorkels....
...on the first Puma it nearly broke my hand! WANTED:
SII or SIII in max 1.5k
Post #55015 25th Jan 2011 8:42pm
Naks
nakatanenga wrote:
On a Td5 you can stall the engine by putting the hand on the snorkel, done this a lot of times while testing airtightness on fresh installed snorkels.... ...on the first Puma it nearly broke my hand!
How do u make a snorkel airtight?
Post #55016 25th Jan 2011 8:44pm
mse
Remember even if you go deeper than the top of the bonnet the water underneath remains much lower unless you stop (yes there is splashing)
Personally I don't think beyond the height point in the bonnet...never had any other need in any other LR Mike
Post #55017 25th Jan 2011 8:48pm
nakatanenga
Germany
we produce 3 different types of 100% waterproof snorkels. 1 each Tdi, Td5 or Puma.
A standard LR or Mantec snorkel is hard to get airtight but with a lot of silicone and GAFFA Tape do a pretty good job. WANTED:
Post #55023 25th Jan 2011 8:57pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
AndrewS did a post on how to seal the Mantec snorkel.
Basically as nakatanenga said - lots of sealant and gaffa Thumbs Up
If you want to do a really thorough job, you need to take the pipework out from the airbox to the snorkel and replace it. If you look at the D4x4 forum, they're doing a post (referenced here somewhere too) on a no-holds barred expedition upgrade on a Defender. They fit a Mantec but properly seal it. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #55032 25th Jan 2011 9:33pm
mse
For a proper snorkel - its safari all the way Mike
Post #55039 25th Jan 2011 10:14pm
SteveS
Yep Safari for me too.
BTW - I get the point made by Mike that the bow wave under the bonnet should produce a lower wave than the front of the car BUT - what if you have to stop or reverse out, you can't keep a constant speed or you hit a large underwater object that slows you down? £10 of plastic pipe and a Saturady morning means that I can choose to go across a ford (ie not a nice tarmac'd road) with some confidence in the knowledge that the only thing saving my diff/gearbox from getting water in it is forward speed and luck.
At the end of the day we all make choices - and some of them are personal - so can't argue with that - based on intended use. Me, well I may go slighly over the top in some areas - but where I'm planning to go there is no AA
Post #55215 26th Jan 2011 8:41pm
BigMike
Norfolk? Laughing
Post #55237 26th Jan 2011 11:35pm
JSG
You can ford a Puma without a snorkel - just can be a bit 'brown trouserish' Shocked
Engine was fine but the carpets were sodden Rolling with laughter
 John
2011 Tdci 110 CSW XS
Post #55258 27th Jan 2011 9:38am
SJM
Great photo Thumbs Up Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #55494 28th Jan 2011 1:41pm
