Home > Puma (Tdci) > nasty whistle from turbo/manifold
Page 2 of 5 <12345>
AndrewS
TD5
Problem
The exhaust manifold mating flange expands and sheers the M8 studs
Fix
Thicker M10 bolts are required with 'special' washers between the manifold and nuts.
TDCi
Problem
The exhaust manifold expands in length by about 20mm and the triangular exhaust to turbo flange warps.
Fix
New Manifold (that will do the same) 130's have feeling's as well you know Smile
Post #54877 24th Jan 2011 9:54pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Removing the webs on the TD5 manifold helps Thumbs Up
Post #54889 24th Jan 2011 11:40pm
AndrewS
Are you sure? I tried that on my V reg Disco TD5 and it ended up bending in at 1 and 5, so out at 3, normally the manifold would go out at 1 and 5 so in at 3 (does that make sense) perhaps take 1/2 the web out? 130's have feeling's as well you know Smile
Post #55040 25th Jan 2011 10:15pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Could mine be warped? I only have 500 miles on the truck. I mean it isn't all the time just in certain gears when I step on the gas. Been like that since I got it I think. Having a turbo diesel is new to me but people have asked what the sound was.
Anyone have a picture of where the black soot would be?
Post #55690 30th Jan 2011 6:27am
defender75
Just wanted to push this thread up. I have no idea what is normal so I wanted a picture of where to look for issues.
thanks
Post #55930 31st Jan 2011 5:59pm
RLD
yes studs 8mm on mine snapped off had to have 10mm put in with a new manifold with some expansion in it RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #55933 31st Jan 2011 6:34pm
defender75
Pictures of issue?
Post #55934 31st Jan 2011 6:37pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
well lanbrover have refused to repair my truck
on the basis it possibly has a remap (but they havnt poved it has)
it has a raised air intake ? and said even with out the other 2 things this would void the warranty alone
and 3rd a non standard exhaust altho it still has the cat on it ?(atm)
this has really p***ed me off
ill repair my self i spose but would have been nice to be given proper evidence as a pose to be ing told out mechaninc THINKS its remapped ?
not happy Evil or Very Mad Evil or Very Mad Evil or Very Mad 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #56271 2nd Feb 2011 6:32pm
defender75
That does suck. Is it for sure the manifold?
Post #56274 2nd Feb 2011 6:49pm
big steve
its the manifold to turbo if you look at andrewS first or secon post on first page and use the thread ull see the pics
steve 2015 2.2 tdci hardtop xs
Post #56275 2nd Feb 2011 6:53pm
defender75
wasn't sure if you had the exact same issue. Annoying I am sure
Post #56284 2nd Feb 2011 7:19pm
defender75
If you have this manifold issue I would assume you would hear it whistle even when you dont drive? I would think being in neutral and stepping on gas you would hear it?
Post #56514 3rd Feb 2011 6:16pm
bob neville
Big Steve
My DC has a non Land Rover raised air intake and the dealer has no issue with it. When the vehicle goes in for engine work/service they ask if it has been mapped/chipped in case they destroy the map. They are always interested in any mods and how much/where from.
Maybe me setting the MD of Land Rover on them 18 months ago had some effect, if it did, it worked as they are considerate and helpful and now have a genuine interest in Defenders and there owners.
Have you appoached another dealer to see what they say ?
Bob
Post #56546 3rd Feb 2011 7:35pm
big steve
hi bob no i havnt
if i do my truck flags up on the system that the warranty is void
i have just had a curtacy email fromt he dealer asking how my exsperiance was and i told them
also i rang customer service they said theyd ring back in 5mins ?
they rung me at 2.45 today nearly 21hrs later i think its discusting
i only have abt 3months of warranty left but i think now
id prefer to do it my self least it will be right ?
Post #56559 3rd Feb 2011 8:18pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
I had my warranty voided by LR due to the RAI and the fact that it had a de-cat on it. She also had BAS stickers all over it and they tried to say it was mapped but I stuck to my guns and they could not prove it so they removed the warranty as said it was for the RAI and de-cat.
Anyway, after many emails, dealer visits and my writing to LR head office a guy called Steve Cafearo called me and said he was going to get a technical guy to cal me.
A chap called me and asked why I had an RAI on and also why I had removed the cat. After explaining I had done the RAI as I was using the Defender as she was supposed to be used and wanting to protect the engine from water intake he said he was happy with that being on.
We then discussed the de-cat pipe and I explained I removed it and the ctr box as I was bashing the he'll out of it. He asked if I had done it for performance gains and I replied no.
After some more discussion he agreed with me and re-installed the warranty.
My advice is to keep on going at them and they will cover the vehicle as the bad publicity is not good for them. LR. Customer services won't be able to help, you need to go higher and go around the dealer as they are worse than useless.
It will take a while but keep on at them and write to LR head office and the MD - you can find his name out from the LR website.
They tried to prove my Defender had been re-mapped but try as they may they could not Wink
Good luck and keep the faith - they will give in if you push hard enough. Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #56571 3rd Feb 2011 8:36pm
Page 2 of 5 <12345>
