Home > Puma (Tdci) > nasty whistle from turbo/manifold
Page 1 of 5 12345>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
im geting that anoying whistle again landrover have sorted it once is there a better way of sorting this out or is it something to just live with ?
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #53356 16th Jan 2011 8:39pm
AndrewS
Is the vehicle re-mapped ? 130's have feeling's as well you know Smile
Post #53358 16th Jan 2011 8:42pm
big steve
it is but currently runing it without it even so there still must be a way ? 2015 2.2 tdci hardtop xs
Post #53359 16th Jan 2011 8:44pm
Naks
Have you checked the turbo inlet hose? It tends to rub against a bolt and develop a leak, leading to the whistling sound.
Post #53360 16th Jan 2011 8:46pm
AndrewS
This is the problem I expect.
http://www.defender2.net/forum/topic457.ht...t+manifold 130's have feeling's as well you know Smile
Post #53361 16th Jan 2011 8:46pm
big steve
interesting did you ever resolve it with new gasket or anything what was the result? 2015 2.2 tdci hardtop xs
Post #53367 16th Jan 2011 9:02pm
RLD
i had this on my TD5 130 as i do have a tune on it it had expanded the manifold and bust off bolts and twisted the manifold so had J&E fix it with a new one with some sort of expansion thingy in bob on no problem RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #53460 17th Jan 2011 4:36pm
AndrewS
New manifold put the car back to standard and sold it. 130's have feeling's as well you know Smile
Post #53462 17th Jan 2011 4:49pm
big steve
ok well i certainly done want to sell it i want a decent solution
cheers steve 2015 2.2 tdci hardtop xs
Post #53496 17th Jan 2011 7:16pm
JSG
Exhaust manifold warping on TD5s is a known problem - especially when tunde due to the extra heat. I had the 90 done in December and the 110 was done earlier last year. John
2011 Tdci 110 CSW XS
Post #54788 24th Jan 2011 2:14pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Is the whistle harmful? My puma whistles or sounds likes an ambulance is behind me at times. I just thought it was the normal turbo sound
Post #54793 24th Jan 2011 3:01pm
big steve
its the result of possible warped manifold or turbo flages and/or the gasket between them
the first time i took it to the dealer they replced the gasket and bolts and said they were loose ?
its now in 12month on being checked again
Post #54800 24th Jan 2011 3:30pm
JSG
We've had the manifolds skimmed on both the Raiders - I was advised to skim them rather than replace them as once they warp due to the heat they shouldn't do the same again. John
Post #54810 24th Jan 2011 4:00pm
Naks
hmm, that does sound like a warped exhaust manifold. A tell-tale sign is black soot around the manifold
Post #54811 24th Jan 2011 4:04pm
big steve
on td5 the temp is higher than on a a puma
i will u let u no wat the dealer say abt the manfold to date only the flange that bolts to turbo on pumas warp ? 2015 2.2 tdci hardtop xs
Post #54812 24th Jan 2011 4:17pm
Page 1 of 5 12345>
