Home > Off Topic > Dogs:- your pictures
Page 51 of 107 <123 ... 505152 ... 105106107>
CatherineF
Awwwhhh what a beauty 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #385342 5th Jan 2015 10:56pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
FAO Rickydodah
Ricky,
That's a few squeezed in there!, I thought there was 4 till I noticed the Black ghost, blending into the background Very Happy
I also noticed you have the travail inner door fitted.
I have been debating one of these for mine but have an issue with my drawers being in the way of the lowest part of the legs.
If at some point you have the time, could I ask you to measure /check if the lower hinge is above the top of the wheel arch boxes please.
As you may be able to see on the pic of my back end Shocked I would not be able to fit one as it would stop my drawers opening.
My idea was , (if it was feasable, ) to cut the doors legs off below the hinge so it finished level with the top of the wheel arch boxes.
This would be the easiest option without going down the route of cutting welding , painting the thing.
Many thanks,
Nick Thumbs Up
Rickydodah wrote:
Bit of a squeeze but they all fit...just.
Post #385347 5th Jan 2015 11:09pm
g-mack
Perc wrote:
Tango, 8 weeks Labrador.
he's a beauty is he fox red? My 109 thread
my youtube channel
Post #385352 5th Jan 2015 11:19pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Holly ..
 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #385368 6th Jan 2015 12:09am
gumdrop
Bobby in the 50th Smile
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #385418 6th Jan 2015 10:28am
Rickydodah
Windowlicker wrote:
FAO Rickydodah
Ricky,
Hi Nick, the lower part of the hinge is pretty much flush with the top of the wheel boxes. I'd say that with a bit of fettling you could raise the whole frame a bit anyway. The door hardware had to be modified a bit as it seems that the bottom locating bolts are in different positions in the 110 from the 90. It wasn't much of a problem just had to extend the brackets, something which you could do to raise it if need be. : Thumbs Up
Good luck and nice looking dog, Regards Richard
 I started with nothing and still have most of it left!
Post #385454 6th Jan 2015 12:56pm
Windowlicker
Hi Richard.
I was hoping there may have been some adjustment available up top Very Happy
With a bit of fettling it sounds like it is going to be no problem.
Thanks for the reply. Thumbs Up
Cheers.
Nick.
Post #385483 6th Jan 2015 3:16pm
Perc
Sweden 2003 Defender 90 Td5 SW Oslo Blue
He is foxred, he has a lovely color and he's born to retrieve Very Happy
 CSW 90 -03
Post #385878 7th Jan 2015 11:03am
Lorryman100
@Windowlicker
The rear dog gate on the 110 is fitted at the bottom of the gate frame by using the bolts that the D loop cargo securing rings use. The frame then goes all the way from the load bed to the two passenger handles mounted above the rear door.
Post #385885 7th Jan 2015 11:23am
Windowlicker
Hi lorryman,
Thanks for the pics, yours looks to be set much further onboard than the picsif Richards , is that possibly due to him have fitted one designed for a 90 do you think.?
The distance yours seems to be inset would actually take valuable space out of the back of mine so hopefully the platform differences account for that.
I think it's doable either way with some fiddling and fettling.
Cheers.
Nick "Procrastination is the thief of time"
Post #385951 7th Jan 2015 2:16pm
Rickydodah
Hi All. I don't think that there's a difference in the gates as Travall list the same for both models. The mounting hole for the D ring on the 110 is around 50mm further forward than the 90, this meant that when I first put the gate in it lent inwards at the bottom and used up too much space. I made up two cranked links to extend the brackets to enable the gate to fit upright. Thumbs Up I started with nothing and still have most of it left!
Post #385983 7th Jan 2015 4:33pm
Rickydodah
Windowlicker wrote:
Hi lorryman,
Thanks for the pics, you're looks to be set much further onboard than the picsif Richards , is that possibly due to him have fitted one designed for a 90 do you think.?
Cheers.
Nick
A picture paints blah blah. Hope that it explains better. Thumbs Up
Post #385989 7th Jan 2015 4:44pm
Windowlicker
Thanks Richard Thumbs Up , gives a better all round idea of dimensions, and what I think will need modding.
Cheers,
Post #386142 7th Jan 2015 10:13pm
NigelM
The Bear. My hunting mate. Birds and Deer, best working dog I have ever had the honour of looking after.
...and the back of his Defender. Platform made of gun cabinet at the front and stacked waffle boards at the back (dual use is always good for space saving) with a rubber anti slip mat on top. Carcass tray slides in below (two tone grey box you can see).
Post #386144 7th Jan 2015 10:23pm
CE TD5
United Kingdom 2005 Defender 90 Td5 HT Cairns Blue
My two labs Dylan 11 and Alfie, now a lot bigger and I can't quite believe is going to be 3 next month. Dylan is chilled and calm and Alfie, well he's a nutter Laughing Dog
Chris
Post #386627 8th Jan 2015 11:46pm
