Home > Off Topic > Dogs:- your pictures |
Windowlicker Member Since: 24 Aug 2014 Location: East yorks Posts: 290 |
FAO Rickydodah
Ricky, That's a few squeezed in there!, I thought there was 4 till I noticed the Black ghost, blending into the background I also noticed you have the travail inner door fitted. I have been debating one of these for mine but have an issue with my drawers being in the way of the lowest part of the legs. If at some point you have the time, could I ask you to measure /check if the lower hinge is above the top of the wheel arch boxes please. As you may be able to see on the pic of my back end I would not be able to fit one as it would stop my drawers opening. My idea was , (if it was feasable, ) to cut the doors legs off below the hinge so it finished level with the top of the wheel arch boxes. This would be the easiest option without going down the route of cutting welding , painting the thing. Many thanks, Nick
Click image to enlarge |
5th Jan 2015 11:09pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
he's a beauty is he fox red? My 109 thread my youtube channel |
5th Jan 2015 11:19pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 699 |
Holly ..
Click image to enlarge 2008 Defender 110 XS SW - M57N2 / 6HP28X |
6th Jan 2015 12:09am |
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 125 |
Bobby in the 50th
Click image to enlarge Cheers Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
6th Jan 2015 10:28am |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
I started with nothing and still have most of it left! |
6th Jan 2015 12:56pm |
Hi Richard.
I was hoping there may have been some adjustment available up top With a bit of fettling it sounds like it is going to be no problem. Thanks for the reply. Cheers. Nick. |
6th Jan 2015 3:16pm |
Perc Member Since: 25 Jan 2013 Location: Westcoast Posts: 18 |
He is foxred, he has a lovely color and he's born to retrieve Click image to enlarge CSW 90 -03 |
7th Jan 2015 11:03am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
@Windowlicker
The rear dog gate on the 110 is fitted at the bottom of the gate frame by using the bolts that the D loop cargo securing rings use. The frame then goes all the way from the load bed to the two passenger handles mounted above the rear door. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
7th Jan 2015 11:23am |
Hi lorryman,
Thanks for the pics, yours looks to be set much further onboard than the picsif Richards , is that possibly due to him have fitted one designed for a 90 do you think.? The distance yours seems to be inset would actually take valuable space out of the back of mine so hopefully the platform differences account for that. I think it's doable either way with some fiddling and fettling. Cheers. Nick "Procrastination is the thief of time" Last edited by Windowlicker on 7th Jan 2015 6:37pm. Edited 1 time in total |
7th Jan 2015 2:16pm |
Hi All. I don't think that there's a difference in the gates as Travall list the same for both models. The mounting hole for the D ring on the 110 is around 50mm further forward than the 90, this meant that when I first put the gate in it lent inwards at the bottom and used up too much space. I made up two cranked links to extend the brackets to enable the gate to fit upright. I started with nothing and still have most of it left!
7th Jan 2015 4:33pm |
A picture paints blah blah. Hope that it explains better. Click image to enlarge Click image to enlarge Click image to enlarge I started with nothing and still have most of it left! |
7th Jan 2015 4:44pm |
Thanks Richard , gives a better all round idea of dimensions, and what I think will need modding.
Cheers, Nick "Procrastination is the thief of time" |
7th Jan 2015 10:13pm |
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 |
The Bear. My hunting mate. Birds and Deer, best working dog I have ever had the honour of looking after.
Click image to enlarge ...and the back of his Defender. Platform made of gun cabinet at the front and stacked waffle boards at the back (dual use is always good for space saving) with a rubber anti slip mat on top. Carcass tray slides in below (two tone grey box you can see). Click image to enlarge |
7th Jan 2015 10:23pm |
CE TD5 Member Since: 20 Nov 2014 Location: UK Posts: 51 |
My two labs Dylan 11 and Alfie, now a lot bigger and I can't quite believe is going to be 3 next month. Dylan is chilled and calm and Alfie, well he's a nutter
Chris Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
8th Jan 2015 11:46pm |
