Home > Puma (Tdci) > Puma squeal |
tonyt Member Since: 30 May 2015 Location: sydney Posts: 3 |
had the same squeal only stopping when pulling the clutch in but stopped after i changed the oil myself possibly low oil from the dealers last service as i olny got 6 litres out just under 10000 kms between oli change
15th Jan 2017 4:41am |
Jed Member Since: 24 Nov 2014 Location: Hertfordshire Posts: 25 |
After having no luck with above i thought I would have to take it in to a garage but before I did this i changed one of the u v joints at the front end which was quite badly gone, after doing this i went out to test the landy to see if it felt better, the squeling noise had totally disappeared and hasn't come back so far.i can't believe that was what was causing the squeal
15th Jan 2017 6:40pm |
PeterA Member Since: 04 Feb 2016 Location: Devon Posts: 9 |
Hi Jed,
Just wondering if your squeal has come back. I have a very similar problem (chirping noise after a couple of miles driving) and after reading your thread checked the UV joints to find one that seems to have a little play in it and as I had just been driving it the joint was warmer than any of the others. Is it an easy job to replace them? Would you do both ends or just the worn one? (defender 110 High Capacity) |
15th Nov 2017 4:44pm |
Manage to do the UJs and the squeal has now disappeared. One of the caps was broken so this probably caused the squeal. the new UJs have grease nipples how often should you grease them?
30th Nov 2017 4:12pm |
