Home > Puma (Tdci) > Puma squeal
Page 2 of 2 <12
Jed
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Cairns Blue
I have now replaced the Tensioner bearing and belt and have also replaced the Turbo Gasket with a thicker one as suggested by someone on here. I have no holes in the rubber hose from the turbo and all other bearings seem ok. Why does it only squeal when engine hot and going along under no load, soon as I put the clutch in it stops when going along?
Post #583744 9th Dec 2016 5:50pm
tonyt
Australia 2013 Defender 110 Puma 2.2 SW Alaska White
had the same squeal only stopping when pulling the clutch in but stopped after i changed the oil myself possibly low oil from the dealers last service as i olny got 6 litres out just under 10000 kms between oli change
Post #593149 15th Jan 2017 4:41am
Jed
After having no luck with above i thought I would have to take it in to a garage but before I did this i changed one of the u v joints at the front end which was quite badly gone, after doing this i went out to test the landy to see if it felt better, the squeling noise had totally disappeared and hasn't come back so far.i can't believe that was what was causing the squeal
Post #593291 15th Jan 2017 6:40pm
PeterA
United Kingdom 2007 Defender 110 Puma 2.4 PU Fuji White
Hi Jed,
Just wondering if your squeal has come back. I have a very similar problem (chirping noise after a couple of miles driving) and after reading your thread checked the UV joints to find one that seems to have a little play in it and as I had just been driving it the joint was warmer than any of the others.
Is it an easy job to replace them? Would you do both ends or just the worn one? (defender 110 High Capacity)
Post #664551 15th Nov 2017 4:44pm
PeterA
Manage to do the UJs and the squeal has now disappeared. One of the caps was broken so this probably caused the squeal. the new UJs have grease nipples how often should you grease them?
Post #667987 30th Nov 2017 4:12pm
Page 2 of 2 <12
