Home > Td5 > TD5 at motorway speed |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Have you got a roof rack?
29th Nov 2016 4:30pm |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 |
Mine too is most comfortable up to about 63, then up to 70mph it doesn't sound happy and over 70 it is fine again.
29th Nov 2016 4:32pm |
chri$ Member Since: 27 Mar 2014 Location: Kent Posts: 16 |
No roof rack. Sounds like a case of TADTS
29th Nov 2016 4:44pm |
Mine struggles due to the roof rack. A disco transferbox may help out
29th Nov 2016 4:53pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
No problems with mine (Ninety)
I get a little drumming between 65-70 but noting much. On French motorways it will cruise at 80+ quite happily. |
29th Nov 2016 5:07pm |
Mine is a bit noisy at speed but I don't think I can blame that on the td5 engine.
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
29th Nov 2016 6:28pm |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 |
Mine behaves exactly the same, ok below 65, noisy above and then quieter above 75 although I rarely do this.
30th Nov 2016 10:33am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2865 |
I had the same drumming/droning noise at 65mph on my TD5 110 CSW. It cleared at 70 mph.
It's a 2005 model with 82,000 miles. I replaced the exhaust system and the noise is no longer there. l fitted a Britpart centre box and rear section, but the rear section was a poor fit and l ended up with an OE rear section. The old exhaust looked OK so l'm guessing the internal baffles were shot? |
1st Dec 2016 9:28pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Yep, same
On my 110 Td5 60 = Fine 60 to 70 noisy and harsh and vibrates 70+ = Fine Same thing on three different sets of wheels |
1st Dec 2016 9:52pm |
Try replacing the exhaust system!
You can do it yourself (jack up the rear wheel to get the rear section out) and the parts cost less than £100. The tailpipe on two aftermarket rear sections l tried was very close to the rear crossmember. I just fitted an OE one but you could probably adjust it by bending the rear mounting a little. |
2nd Dec 2016 7:19am |
Lightning
You could be on to something... I wouldn't be surprised if after 120000 miles and 12 years the exhaust is not in the greatest shape. |
2nd Dec 2016 9:57am |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 |
I have the transfer case conversion and still find that 65 is the comfortable motorway cruising speed. It's also relaxing for me as it's faster than the trucks and slower than the cars compel the outside lane
2nd Dec 2016 8:32pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Lets not forget how sound is just vibrating air. My theory is the frequency of the sound created at ~70 penetrates perfectly into the cab, after ~75 the frequency is too high.
I'm unsure how well this will hold up in court |
3rd Dec 2016 1:14pm |
