Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Another little job done this evening. Got a raptor binnacle mount to replace my original plastic one.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I hadn't realised how bad it was until I fully removed it. Totally broken! The new one looks loads better. The dash even lines up as landrover intended! I might make a cover panel for the side out of the original plastic to make it look factory Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Nov 2017 7:23pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Sounds good with the "factory look " when you get it done 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
9th Nov 2017 9:05pm |
A bit of colour coding today. Long over due dirt defenders and I had a spare numberplate light cover so did that too
Click image to enlarge Click image to enlarge That's just the base coat. Lacquer to go on top yet 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th Nov 2017 12:12pm |
All finished. Dry over night and fit tomorrow hopefully
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th Nov 2017 2:22pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Good spraying skills the finish looks great. Did you use rattle cans? And what primer?
24th Nov 2017 2:34pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
great finish.. 1993 200Tdi Defender 90
24th Nov 2017 2:42pm |
thank you!
I used novol plastic primer Click image to enlarge followed by solvent base coat from my spray gun and then a few coats of simoniz acrylic lacquer. Click image to enlarge Trick is to keep the aerosol warm in hot water in a bucket. Then about 10 mins between coats. Got impatient and fitted the light cover haha Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
24th Nov 2017 3:27pm |
Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228 |
Very nice. Well done Peter,
Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
24th Nov 2017 4:05pm |
Thank you 2002 90 Td5 Station Wagon
24th Nov 2017 7:08pm |
Yeah I looked at the binnacle but there were a couple of niggles, you can't use the illuminated heater controls which I quite like. They do look solid though! 2002 90 Td5 Station Wagon
24th Nov 2017 8:22pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5208 |
The heater control panel you can get from ebay but it would need a bit of a rework to get it to fit right. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
24th Nov 2017 8:27pm |
I already have illuminated panels, they don't fit with the metal binnacle unfortunately.
Got the arch extensions on today. Looking much better than when they were black Click image to enlarge Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Nov 2017 4:31pm |
how do you get the illuminated feature? I bought my dad a replacement binnacle which has the feature, he bummed the metal one off me sadly. So I thought it I will use it if I can. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
25th Nov 2017 4:41pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 504 |
The colour coding paintwork looks fantastic! Great job Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
25th Nov 2017 5:03pm |
