Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4787 |
Luckily the td5 has 'smart' interior lights as standard that illuminate when you disarm the alarm and then fade out after 15 seconds when you close the door. They also turn off after 15 minutes if you leave the door open to save the battery.
I put the footwell lights in primarily so I can see what I'm doing with my pedal lock 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Jul 2017 9:12pm |
And here is one of the rear door lights in the dark
Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Jul 2017 9:42pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5205 |
that looks fantastic! I wonder if they use the same Delay relay as the Rovers, The rover 75 speaks to mind with you saying about the smart system. I did keep the fuse boxes with all the relays for spares for ours, as I thought that I could use the lights on buzzer, but I don't think that its the same on the defenders sadly.
What did you use to wire in the floor pan lights? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
25th Jul 2017 9:50pm |
I wired the footwell lights into the live and earth from the 'doors open' side of the interior light so any time the doors are opened they're on but the don't come on if you manually turn the lights on in the headlining. The interior lights in td5s are controlled by the factory alarm module so you can turn some features on and off 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
25th Jul 2017 10:17pm |
ah spot on, Shame the MGF interior mirror doesn't fit these, you could have had the extra map lights. I do wonder if a 406 review mirror would work with the auto dim system, I have that installed in the 306, which is a mega neat feature!
Might be an idea for you Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
25th Jul 2017 10:23pm |
I have modified a range rover classic mirror in mine with auto dim and map lights. I need to wire it in still
I think there might be a picture of it earlier in this thread 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Jul 2017 6:42am |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
Loving the lights and interior trim...even without the Alcantara I just have the plastic mud trims in the back of mine, no carpet, just rubber mat.. but then I do have a big wet dirty Labrador getting in occasionally... Great work Grafty 1993 200Tdi Defender 90
26th Jul 2017 4:54pm |
If I put my spaniels in the back I put them in their cage with bed sheets everywhere. But even that is emergency measures usually take the FFRR for the dogs 2002 90 Td5 Station Wagon
26th Jul 2017 5:40pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Looks much better with all the trim in than the last time i saw it 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
26th Jul 2017 9:59pm |
Got 5 minutes to myself today so changed to a 19 inch wiper blade on the rear. The difference in wiped area is massive. Basically the whole aperture you can see through is wiped. Obviously only a mod for panoramic rear glass
This is the original wiper in the 19 inch wiped area. Click image to enlarge And this is the new wiped area. Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th Jul 2017 7:35pm |
That's one thing I need to get working on mine is the rear wire! Another mod you might beable to use, these have the same wipers I think as metros and minis, The metro lads used to use the mk1 clio wipers for the added style. might be a little idea for you Not sure if the larger wiper blade will fit though.
edit, get the lettering on you tyres done in white Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
29th Jul 2017 12:26am |
Because my tyres are 285s I don't think a chunkier wiper arm would fit, I have about 3mm clearance between the arm and the tyre currently
I do like white lettering on tyres but I'm not sure it would suit mine as it stands 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
29th Jul 2017 7:22am |
Are you good with photo shop? if not get some one to photo shop the white lettering on.
I recon it would, my parents defender did it to theirs, and it really did set the rear off nicely with the tinted glass. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
29th Jul 2017 12:15pm |
I'm afraid Photoshop is not my forte.
Microsoft paint however.......... 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
29th Jul 2017 10:23pm |
