Home > In Car Electronics > Ignition live
Domfish
Ignition live
Is there an ignition live anywhere under the front seats defender TD5 as fitting something that needs on there and dont really want to run a wire over gearbox tunnel!!
Post #577455 13th Nov 2016 10:07am
dgardel
Italy
easy way:
from the lighter on the dash with a "T" cable.....
route it under the carpets..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #577696 14th Nov 2016 9:23am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Would putting one of these in the cig lighter fuse work instead?
http://www.halfords.com/technology/car-aud...add-a-fuse Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #577702 14th Nov 2016 10:04am
mcma1
Best thing I did was an ignition live module from mobile centre, feeding half of a blue sea fuse box. makes things handy for adding various things Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #577865 14th Nov 2016 11:25pm
VeeTee
Netherlands
Yes, I used that too. Thumbs Up Cheers, Vincent
MySite
Post #577871 14th Nov 2016 11:42pm
Martin
Site Admin
The lighter socket is not ignition switched, it is switched in the "AUX" position (one click before ignition position).
There's no ignition switch supply on the Td5 underseat fuse box, they are all permanent.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #577898 15th Nov 2016 8:56am
Chopperone
Ignition live module
I have had a search thro' Mobilecentre & I can't find the ignition live module that is being spoken about.
Has anyone got a link to it please
Guy
Post #583411 8th Dec 2016 8:27am
L90Andy
I've got one and it works well, but couldn't find it on the website either.
I spoke (telephone!) with Tim who informed me about it. He refers to it as a IGNSNS module... Instagram: L90andy
Post #583412 8th Dec 2016 8:34am
Chopperone
I have had another look on their website- it is mentioned in their heated seat wiring looms but they call it an ignition feed box.
However it doesn't appear to be available as a stand alone item.
I will call them this morning & suggest that they a.) describe it more clearly & b.) sell it a stand alone item.
This would appear to be a very useful piece of kit which is far safe/ better than taking individual feeds from around the vehicle PROVIDING fused links are used at all times.
If I have any success I will re post here & under a separate post for others to see.
Guy
Post #583425 8th Dec 2016 9:31am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I've got one that I got from Mobile Centre, but haven't fitted and don't plan to use. I'll try to dig it out and take a photo.
Post #583447 8th Dec 2016 11:38am
Chopperone
Ignition Live module
http://www.mobilecentre.co.uk/index.php?ma...cts_id=536
I have spoken with Mobile Centre & made the suggestion that they also show this as "An ignition live Sensing Module" - that way we might find it in the future.
I think they are a very useful bit of kit.
Guy
Post #583461 8th Dec 2016 1:10pm
mse
Does that module take a perm feed and sense the ignition on to create an ignition feed? Mike
Post #583464 8th Dec 2016 1:31pm
L90Andy
Yep, that's exactly it. I've got one to power my DRL's. They come on a few seconds after starting once the alternator has kicked in. Instagram: L90andy
Post #583467 8th Dec 2016 1:36pm
mse
Ive looked for something like that for ages - whats the max voltage through it before it needs a relay? Mike
Post #583471 8th Dec 2016 1:51pm
Cupboard
I guess you mean the maximum current? That's listed as 20A per channel and it's got two channels.
That unit looks just like a TEC3M which is a fairly standard and dull unit. Some people rate it as 30A total.
Post #583472 8th Dec 2016 1:59pm
