Home > In Car Electronics > Ignition live |
easy way:
from the lighter on the dash with a "T" cable..... route it under the carpets..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Nov 2016 8:23am |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 722 |
Would putting one of these in the cig lighter fuse work instead?
http://www.halfords.com/technology/car-aud...add-a-fuse Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
14th Nov 2016 9:04am |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2925 |
Best thing I did was an ignition live module from mobile centre, feeding half of a blue sea fuse box. makes things handy for adding various things Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
14th Nov 2016 10:25pm |
Yes, I used that too. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
14th Nov 2016 10:42pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
The lighter socket is not ignition switched, it is switched in the "AUX" position (one click before ignition position).
There's no ignition switch supply on the Td5 underseat fuse box, they are all permanent. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
15th Nov 2016 7:56am |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 |
I have had a search thro' Mobilecentre & I can't find the ignition live module that is being spoken about.
Has anyone got a link to it please Cheers Guy |
8th Dec 2016 7:27am |
I've got one and it works well, but couldn't find it on the website either.
I spoke (telephone!) with Tim who informed me about it. He refers to it as a IGNSNS module... Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
8th Dec 2016 7:34am |
I have had another look on their website- it is mentioned in their heated seat wiring looms but they call it an ignition feed box.
However it doesn't appear to be available as a stand alone item. I will call them this morning & suggest that they a.) describe it more clearly & b.) sell it a stand alone item. This would appear to be a very useful piece of kit which is far safe/ better than taking individual feeds from around the vehicle PROVIDING fused links are used at all times. If I have any success I will re post here & under a separate post for others to see. Cheers Guy |
8th Dec 2016 8:31am |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 619 |
I've got one that I got from Mobile Centre, but haven't fitted and don't plan to use. I'll try to dig it out and take a photo.
8th Dec 2016 10:38am |
http://www.mobilecentre.co.uk/index.php?ma...cts_id=536
I have spoken with Mobile Centre & made the suggestion that they also show this as "An ignition live Sensing Module" - that way we might find it in the future. I think they are a very useful bit of kit. Cheers Guy |
8th Dec 2016 12:10pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
Does that module take a perm feed and sense the ignition on to create an ignition feed? Mike
8th Dec 2016 12:31pm |
Yep, that's exactly it. I've got one to power my DRL's. They come on a few seconds after starting once the alternator has kicked in. Instagram: L90andy
8th Dec 2016 12:36pm |
Ive looked for something like that for ages - whats the max voltage through it before it needs a relay? Mike
8th Dec 2016 12:51pm |
I guess you mean the maximum current? That's listed as 20A per channel and it's got two channels.
That unit looks just like a TEC3M which is a fairly standard and dull unit. Some people rate it as 30A total. |
8th Dec 2016 12:59pm |
