![]() | Home > In Car Electronics > Ignition live |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
I didnt think of it like a VSR Split charge unit. 20ampsx2 would be more than enough for the sorts of things i needed Mike
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 727 ![]() ![]() ![]() |
Instructions direct from Tim @ Mobile centre:
On the IGNSENS module connections are as follows: A Power in from battery positive via suitable fuse � use either terminal marked 12V B Yellow wire from DRL kit C Not used D Not used E Battery negative Worked for me, good luck. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
Thanks
Yes i have power in on A (first one), earth on E and output on B - but it didnt seems to switch on the ignition live feed. Ill have another check tomorrow, maybe with a multi-meter Mike |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 87 ![]() ![]() ![]() |
Thanks for the info with this thread fellas. I've been frustrated by lack of switched feeds, and don't want to overload the cig lighter circuit, so just ordered one of these units from the Mobile Centre.
It'll provide feeds for the Dash cam, Off road Nav unit and rear camera for my caravan. Thanks again. Ken |
Mine seems to be working and it does a good job.
I find the lack of power feed frustrating with the defender dash, good luck Mike |
I've received my module from the UK, but when connected to the battery (terminal A for + and E for neg) b, c,and d are powered up when the ignition is off, so the switching function isn't working.
Is there adjustment with the Screw inside the housing that I need to make perhaps? Thanks for any info re this. Ken |
