Home > In Car Electronics > Ignition live
Page 2 of 2 <12
mse
I didnt think of it like a VSR Split charge unit. 20ampsx2 would be more than enough for the sorts of things i needed Mike
Post #583497 8th Dec 2016 4:36pm
mse
L90Andy wrote:
Yep, that's exactly it. I've got one to power my DRL's. They come on a few seconds after starting once the alternator has kicked in.
Just fitted mine, I'm not sure if it's working, as the device didn't seem to come on. before I check it tomorrow, a quick question, did you have to set anything or was it plug and play? Mike
Post #589098 31st Dec 2016 10:22pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Instructions direct from Tim @ Mobile centre:
On the IGNSENS module connections are as follows:
A Power in from battery positive via suitable fuse – use either terminal marked 12V
B Yellow wire from DRL kit
C Not used
D Not used
E Battery negative
Worked for me, good luck. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #589101 31st Dec 2016 10:49pm
mse
Thanks
Yes i have power in on A (first one), earth on E and output on B - but it didnt seems to switch on the ignition live feed.
Ill have another check tomorrow, maybe with a multi-meter Mike
Post #589103 31st Dec 2016 11:30pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Thanks for the info with this thread fellas. I've been frustrated by lack of switched feeds, and don't want to overload the cig lighter circuit, so just ordered one of these units from the Mobile Centre.
It'll provide feeds for the Dash cam, Off road Nav unit and rear camera for my caravan.
Thanks again.
Ken
Post #597171 29th Jan 2017 8:18am
mse
Mine seems to be working and it does a good job.
I find the lack of power feed frustrating with the defender dash, good luck Mike
Post #597206 29th Jan 2017 11:05am
Baytown
I've received my module from the UK, but when connected to the battery (terminal A for + and E for neg) b, c,and d are powered up when the ignition is off, so the switching function isn't working.
Is there adjustment with the Screw inside the housing that I need to make perhaps?
Thanks for any info re this.
Ken
Post #607505 7th Mar 2017 1:08pm
Page 2 of 2 <12
