![]() | Home > Maintenance & Modifications > Roof Spot lights and A bar spots |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
I dont always say this so sit down...Leeds is right
![]() ![]() The LR switch might be more like £11/12 now and a few £ for the connector - but its so far better than the ring its not worth a debate Mike |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I would second that.... the kit comprises of all the parts needed.... but, the wires are too high a gauge, the conectors are as good as a chocolate tea-pot and the relay is not weatherproof at all. The best universal kit I have worked with is the Lightforce one: http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Yes it is £50+ but the quality shows through. Otherwise... cheaper option would be to just buy all the seperat components and put it all together ![]() Glyn ![]() Just as a warning though. Yes by buying a cheap kit you might save £35, but if it melts through, you either have to buy a new better quality kit (Buy cheap, buy twice) or at the other end of the scale, you need to buy a new truck because yours has set alight. |
Plus modern thinwall cable is so much easier to route and work with! Mike
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Thanks Guys....i have the LR switches already.....but i know nothing about wiring could you put me in the right direction what i need i have got 4 roof spots to wire and 2 front spots.....also what rating wire to get and what rating relays i need...also what fuse box ... if any of you have a wiring diagram that would be great or if anybody could tell me where to mount the relays how far should the inline fuse be from the relay what size fuse...i think you get the picture
So what you are saying is...... 'fit a kit for me'? ![]() Glyn ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
The switch is £6, orded it yesterday from Guy Salmon in Sheffield.
Online sellers all wanted £7 plus £6 postage! Part number - YUG000540LNF You dont have to have the plug, you can just solder onto the pins at the back of the switch and put a bit of heat shrink over it. So far the loom has cost me £6, hopefully finish the job over the weekend. |
What a guy...good man Glyn...
![]() Glyn i reckon i could do this... just need putting in the right direction...i've even looked at the LR switches and thought ![]() |
Im surprised its now only £6 it was more - although i got it through sources THe plug is a much better the soldering the pins (which is awquard anyway) for a few pounds! Mike |
Paul i have the LR Switchs and the plug that go's in the back
You didnt say search for all the fitting info on here ![]() |
Cheers Mike ill have a look
always welcome http://www.defender2.net/forum/topic795.ht...ght+switch Here she is Mike |
Nice one mate
Ive orded it now and paid, doh! Thanks. Ive been looking for the diagram, i had a print out, but a bit of searching and ive found it.. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
