Home > Maintenance & Modifications > CSW Rear Sliding Window removal... help please! |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
If you look on the out side frame you will.see a rubber strip. Remove the rubber strip and it will expose all the pop rivets which hold the unit in
Drill out the rivets and remove the unit. If you still want to remove the glass the frame splits in two and is held together by flush mounted screws. Remove them and pull the unit apart |
4th Sep 2016 11:00pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6304 |
and I thought these units were glued in place - or is that just the pumas?
5th Sep 2016 7:04am |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
They are bonded in place from 2004ish onwards as the robot which did it was transferred from the disco2 production line!
6th Sep 2016 5:57am |
on that basis I guess it's a knife or cheese all the way round (without removing too much paint) and they 'should' just drop out?
good luck. |
6th Sep 2016 5:59am |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 |
That was what I thought.... I have no rubber around my rear windows.... just two pieces of hard plastic.
I guess ill go find some cheese wire!!! |
8th Sep 2016 11:34pm |
Dont suppose anyone has access to an exploded diagram of how the window and all its pieces fit together.
If i really do need to cut the window out by cutting through the bonding material i would be nice to know that after all that work it will just "fall" out. |
9th Sep 2016 12:01am |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2900 |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
10th Sep 2016 6:12pm |
