Home > Maintenance & Modifications > CSW Rear Sliding Window removal... help please!
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
Good evening... another quiz for you guys....
Im wanting to remove the rear sliding windows in my 110 CSW. These are being replaced by "locker" hatches into the rear load space.
I want to remove everything so that I can square the Radius' of the current window cut outs and then fit my hatches...
Ive looked at the windows and can't work out how I remove them.
One assumes I need to remove the external black plastic surrounds then i can remove the glass and then i can "push" the window frame into the car....
Is this the correct procedure?
How do I remove the first window surround?
Thanks
Ross
Post #561458 4th Sep 2016 10:30pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
If you look on the out side frame you will.see a rubber strip. Remove the rubber strip and it will expose all the pop rivets which hold the unit in
Drill out the rivets and remove the unit. If you still want to remove the glass the frame splits in two and is held together by flush mounted screws. Remove them and pull the unit apart
Post #561461 4th Sep 2016 11:00pm
Caterham
and I thought these units were glued in place - or is that just the pumas?
Post #561490 5th Sep 2016 7:04am
Lotus_esprit_s1
They are bonded in place from 2004ish onwards as the robot which did it was transferred from the disco2 production line!
Post #561773 6th Sep 2016 5:57am
Caterham
on that basis I guess it's a knife or cheese all the way round (without removing too much paint) and they 'should' just drop out?
good luck.
Post #561774 6th Sep 2016 5:59am
tyrannosauROSS
That was what I thought.... I have no rubber around my rear windows.... just two pieces of hard plastic.
I guess ill go find some cheese wire!!!
Post #562601 8th Sep 2016 11:34pm
tyrannosauROSS
Dont suppose anyone has access to an exploded diagram of how the window and all its pieces fit together.
If i really do need to cut the window out by cutting through the bonding material i would be nice to know that after all that work it will just "fall" out.
Post #562604 9th Sep 2016 12:01am
mcma1
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #562960 10th Sep 2016 6:12pm
