![]() | Home > Puma (Tdci) > Engine and Radio Issues |
Rough idle can be down to fuel starvation whether from a failing VCV or blocked fuel filter to biological contamination of the fuel lines.
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
My situation is somewhat related to this as when I rev the engine during normal drive, I get a whining sound, almost like the turbo coming from the radio when listening to music. The sound cannot be heard when the radio is off. Have LEDs but it also happens when the lights are off. My antenna snapped off though, could that have contributed? I'm planning to replace it with a Hirschmann Radio antenna from Nakatanenga with the ground. Will this solve my woes?
I never experienced this issue before. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20702 ![]() ![]() |
This may possibly of interest / help:
http://www.carstereo.com/help/Articles.cfm?id=71 |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
I suspect a dodgy earth may be causing these issues.
Can anyone pinpoint all the earthing points on a 2007 puma 2.4tdci 110 SW that I should check? Many thanks Mark |
I know of one up front under the front wheel arch on the outrigger, can't remember if it was OS or NS. Fairly easy to find.
Another on the transfer box underneath, intended for the rear loom. Be careful with the bolts especially the one on the outrigger as IIRC they can shear so just a warning. Best thing you can do is clean, tighten. (To a tight but not FT!) then corrosion protect once fitted back. Anyone know of any other earth points? I'd be interested to know also if anyone does know. |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
Im in agreement with lorryman, my 07 idled roughly changed the VCV did the learn and was fine afterwards.
Couldnt see what was wrong with the old one. "Rafiki" 2007 110 STW - Rolling rebuild. |
Thanks for your replies guys.
Can anyone point me in the direction of the locations of all the earth points? Many thanks Mark |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
That's fantastic! Many thanks
I've been looking for this information for quite a while now myself. I'm presuming that this still applies for 2011 Pumas?
Also, thanks, custom90steve! The article you linked seems to describe what I'm experiencing to a "T". Will check these out and let you know if it solves anything. Funny that this was never an issue until I lost the antenna. |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge trying to get my head round Land Rovers connections their drawing refer to joints and ctaps but don't reference there location C00550 is mentioned and shown on drawings with the connection pins but no mention in their connection schedule.I know that C00550 is centre of the engine compartment rear and assume the connector is as the freelander a natural coloured multi plug that excepts tab earth wiresa image of the c0550 would help ,have attached header C0289 located behind the right of the dash which could be a source to trace the earth path |
Earthing as I see it assuming c0550 as earth stud and not multi connector anyone confirm this
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 33 ![]() ![]() |
Did you get to the bottom of this one? I'm fairly certain I'm getting interference from my LEDs but also suspicious of a grounding issue as well. When the bluetooth adapter is plugged in the lighter and charging there's terrible noise on the radio (connected via the aux port). Also, rarely, I get a slight whirring when the compressor for the AC is engaged. Odd symptoms. Tackling it this week. 110 SW 2.4 IZUMI BLUE |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2230 ![]() ![]() |
Vaucluse last posted in the forum in 2018, and last posted on this subject in 2016.
I suspect they will not reply. |
