Home > Puma (Tdci) > Bolts
DefenderOfTheEarth
Bolts
There are four pairs of bolts just below the line of the tail lights. Three pairs are fine, the ones just to the bottom left of the spare wheel are slightly corroded. Any idea where I can get a new pair?
Many thanks!
Excuse the dreadful mobile phone pic...
 Defender 110XS SW gone... now VW California 180 4 Motion.
Post #49562 23rd Dec 2010 5:06pm
RLD
any good iron monger or steel stockist will have them google engineering supplies something will come up or yellow pages RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #49563 23rd Dec 2010 5:14pm
dgardel
Italy
A good stainless steel kit....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49566 23rd Dec 2010 5:18pm
AndrewS
Are you still in warranty Question 130's have feeling's as well you know Smile
Post #49567 23rd Dec 2010 5:18pm
Lorryman100
Replace them with stainless steel, you can buy replacement bolts for your landy.
http://a2stainless.co.uk/default.aspx
Thumbs Up
Post #49568 23rd Dec 2010 5:19pm
DefenderOfTheEarth
Andrew - yep - But Approved Used so not as watertight at the original LR one.
I'm not brilliant on bolt sizes - any ideas? Obviously want stainless or very well galvanised! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #49569 23rd Dec 2010 5:20pm
Lorryman100
You can get replacement fixing kits for nearly every surface mounted bolt............. Paddocks, Craddocks, Mudstuff etc all do them.
http://a2stainless.co.uk/Crossmember-Chassis-fixings_B2338J.aspx
Believe the ones on the bottom right of the above page are what you are after.
Post #49570 23rd Dec 2010 5:25pm
DefenderOfTheEarth
Lorryman - you're a star - cheers! Very Happy Defender 110XS SW gone... now VW California 180 4 Motion.
Post #49577 23rd Dec 2010 5:49pm
TC
+1! The tub bolts are quite bad on mine....will order a full 110 pack. Cheers! Thumbs Up
Post #49580 23rd Dec 2010 6:20pm
Are stainless bolts as strong as the standard galvanized ?
Why does LR not use stainless as standard ?
Post #49606 24th Dec 2010 6:23am
Grockle
they are the rear seat belt mounts,don't use stainless bolts they are to brittle for the job,get them changed under the warranty common fault poor plating 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #49612 24th Dec 2010 8:32am
TC
So I should also go back to main dealer and order replacements? I take it they are galvanised not stainless? Is it likely they will end up going the same way?
Post #49614 24th Dec 2010 8:41am
mse
It seems a batch of vehciles suffer from it (i saw them starting to rust at the factory when in the cars!)
I think it was probably a poor batch - deal and get them to replace and fit. Mike
Post #49617 24th Dec 2010 9:07am
Grockle
no plated steel bolts,the dealer will change them and the washers 2.4 90 XS
Post #49621 24th Dec 2010 9:13am
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
Had mine replaced under warranty
C.
Post #49626 24th Dec 2010 9:24am
