![]() | Home > Puma (Tdci) > Bolts |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
any good iron monger or steel stockist will have them google engineering supplies something will come up or yellow pages RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
A good stainless steel kit....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Are you still in warranty
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Replace them with stainless steel, you can buy replacement bolts for your landy.
http://a2stainless.co.uk/default.aspx ![]() |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Andrew - yep - But Approved Used so not as watertight at the original LR one.
I'm not brilliant on bolt sizes - any ideas? Obviously want stainless or very well galvanised! Defender 110XS SW gone... now VW California 180 4 Motion. |
You can get replacement fixing kits for nearly every surface mounted bolt............. Paddocks, Craddocks, Mudstuff etc all do them.
http://a2stainless.co.uk/Crossmember-Chassis-fixings_B2338J.aspx Believe the ones on the bottom right of the above page are what you are after. |
Lorryman - you're a star - cheers!
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
+1! The tub bolts are quite bad on mine....will order a full 110 pack. Cheers! ![]() |
Are stainless bolts as strong as the standard galvanized ?
Why does LR not use stainless as standard ? |
they are the rear seat belt mounts,don't use stainless bolts they are to brittle for the job,get them changed under the warranty common fault poor plating 2.4 90 XS
So I should also go back to main dealer and order replacements? I take it they are galvanised not stainless? Is it likely they will end up going the same way? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
It seems a batch of vehciles suffer from it (i saw them starting to rust at the factory when in the cars!)
I think it was probably a poor batch - deal and get them to replace and fit. Mike |
no plated steel bolts,the dealer will change them and the washers 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
Had mine replaced under warranty
C. |
