Home > Puma (Tdci) > Bolts |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
any good iron monger or steel stockist will have them google engineering supplies something will come up or yellow pages RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
23rd Dec 2010 5:14pm |
A good stainless steel kit....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Dec 2010 5:18pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Are you still in warranty 130's have feeling's as well you know
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Replace them with stainless steel, you can buy replacement bolts for your landy.
http://a2stainless.co.uk/default.aspx |
23rd Dec 2010 5:19pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Andrew - yep - But Approved Used so not as watertight at the original LR one.
I'm not brilliant on bolt sizes - any ideas? Obviously want stainless or very well galvanised! Defender 110XS SW gone... now VW California 180 4 Motion. |
23rd Dec 2010 5:20pm |
You can get replacement fixing kits for nearly every surface mounted bolt............. Paddocks, Craddocks, Mudstuff etc all do them.
http://a2stainless.co.uk/Crossmember-Chassis-fixings_B2338J.aspx Believe the ones on the bottom right of the above page are what you are after. |
23rd Dec 2010 5:25pm |
Lorryman - you're a star - cheers! Defender 110XS SW gone... now VW California 180 4 Motion.
23rd Dec 2010 5:49pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
+1! The tub bolts are quite bad on mine....will order a full 110 pack. Cheers! |
23rd Dec 2010 6:20pm |
Are stainless bolts as strong as the standard galvanized ?
Why does LR not use stainless as standard ? |
24th Dec 2010 6:23am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
they are the rear seat belt mounts,don't use stainless bolts they are to brittle for the job,get them changed under the warranty common fault poor plating 2.4 90 XS
24th Dec 2010 8:32am |
So I should also go back to main dealer and order replacements? I take it they are galvanised not stainless? Is it likely they will end up going the same way? |
24th Dec 2010 8:41am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
It seems a batch of vehciles suffer from it (i saw them starting to rust at the factory when in the cars!)
I think it was probably a poor batch - deal and get them to replace and fit. Mike |
24th Dec 2010 9:07am |
no plated steel bolts,the dealer will change them and the washers 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
24th Dec 2010 9:13am |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
Had mine replaced under warranty
C. |
24th Dec 2010 9:24am |
