Home > Puma (Tdci) > Puma 2.4 not starting ..... immobiliser???
Page 8 of 12 <123 ... 789 101112>
Scarvister87
Thank you Martin that did the trick starts first time every time.
Cheers 👍
Post #814228 8th Feb 2020 9:03pm
ArielDangaran
Philippines
Hi problem with defender 2011
P1602-31
Lost commu ication on PCM and no immobilizer indicator blinking on the cluster
Post #842678 9th Jul 2020 4:30am
ArielDangaran
Philippines
Hello
Can anyone help me diagnose a trouble code of p1602-31 on a defender 2011
The symtoms was alarm buzzes than low car batterry replaced and it does not start anymore
The key fob with two button remote is working on doorlocks
Thanks for anyhelp you can give.
Post #843073 10th Jul 2020 11:39pm
AJTagri
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Hi. Can any one explain how to do the instrument cluster bypass to get my 2007 2.4 puma running again ?
Thanks
Post #866477 10th Nov 2020 10:24am
Martin
Site Admin
Look for my post at the bottom of page 7 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #866481 10th Nov 2020 10:32am
Martin
Site Admin
Page 7 of this thread Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #866487 10th Nov 2020 11:10am
AJTagri
Thanks for the help. All sorted
Post #866532 10th Nov 2020 4:54pm
Martin
Site Admin
Thumbs Up Thanks for taking the time to come back and report it worked Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #866587 10th Nov 2020 9:22pm
JonnyM92
Similar issue here on my 2011 2.4.
Won’t even attempt to turn over, nothing. Lights illuminate as normal & vehicle locks and unlocks ok.
I did get it going yesterday - disconnected batter, reseated relays & fuses, unplugged the green 10AS box & plugged back in.
It worked and was ok for the afternoon.
Come to move today & started ok and moved but then hasn’t started since. Doing the above still didn’t work.
I’ve had the battery on charge for the afternoon but still no joy.
Any ideas before I get it towed to my indy garage?
Post #869208 23rd Nov 2020 7:48pm
vinny
Ireland 1987 Defender 90 Other PU Java Black
Hi Martin I’ve had constant problems trying to find the P068a issue and tried connecting pins 3&4. It started straight away. I now have the clocks in pieces and can’t see a problem with the solder on the board!
Pins 3 and 4 are on the top right and the tracks lead to the 2 unused holes to the right of the pins. Can I solder some wire in these holes to make the connection?
Post #891999 16th Mar 2021 10:32pm
vinny
Soldered the no 3 and 4 pins together today and so far so good. Had to clear the faults from the ecu but otherwise easy fix.
Post #892456 18th Mar 2021 8:26pm
vinny
Well that didn’t last long. Problem returned with the pcb pins soldered together. Next up is to remove the pins from the plug
Post #892723 19th Mar 2021 10:05pm
vinny
Removed pins from the plug and joined them. Problem now solved... again Whistle
Post #893116 21st Mar 2021 10:53pm
MarkHornby
United Kingdom 2007 Defender 110 Td5 XS CSW Bonatti Grey
I had this problem at the end of 2019. My mechanic had the car for a couple of months - then bang - Lockdown 1.0. My mechanic had to shield due to medical issues and nothing happened on the car for a few months. The pin 3 and 4 link trick didn’t work and everything else we tried made no difference. In desperation I bought a 2.5 TD5 engine and an R380 gearbox plus many other bits and the car is being re-created as a FrankenFender. After 15 months without it I’m looking forward to finally hearing the thing fire up soon. I’m not too bothered about replacing the engine as the original 2.4 Transit engine had major problems anyway and would only have lasted a few thousand miles more - if that. Yes it’s a drastic solution to a non starting Puma but sometimes you just have to bite the bullet and do what needs doing.
Post #893940 25th Mar 2021 6:29pm
JBLancs
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Martin wrote:
If the rpm needle moves during cranking it probably isn’t the crank sensor.
The "shunt" is actually a bypass of the wiring of the immobiliser comms link through the instrument pack.
Land Rover did this themselves when the 2.2 was introduced.
You need to access the instrument pack connector, remove it and make a temporary link between pins 3 and 4 with the likes of a straightened out plain metal paper clip.
If it now fires, your problem is the immobiliser link and you have two options:
Send the instrument pack for repair of the soldering of the socket to the PCB (I can do this for you through my business) - or do it yourself if capable Smile
Alternatively dismantle the connector and remove pins 3 and 4 (light green and grey wires to both) and join them permanently. Or if you like, cut the light green and grey wires where they enter the connector and join the loom sides together permanently, bypassing the cluster.
This makes the comms link between the 10AS alarm/immobiliser and the ECU a single wire without the instrument pack in the circuit (as per the 2.2).
The instrument pack will now log a fault if diagnosed as it does not see an incoming signal from the immobiliser, but this does not affect the instrument pack or vehicle operation whatsoever.
Also I feel this is NOT a security issue as the immobiliser itself is not bypassed, and this factory design of "in and out" wiring via the instrument pack only means that the engine won’t start if the instrument pack is missing.
However a missing instrument pack would be no problem for a thief as bridging 3 and 4 (on the now easily accessible connector) restores the link, which is clear from the wiring diagrams.
I fixed a 2010MY basic spec Puma with this issue last week. It would crank, and the RPM needle moved, but an signal tester showed the ECU wasn’t firing the injectors at all. Bridging 3 and 4 allowed it to start straight away Cool
This looks like exactly the issue I have had with mine. Currently the two wires for the loom have been cut and joined permanently together. Knowing this now an instrument cluster repair would have been a nicer repair. Does anyone know of a source for the connector plug and pins into the back of the instrument cluster? Connector C1040.
Post #943060 19th Feb 2022 4:36pm
