![]() | Home > Maintenance & Modifications > EGR shut to minimium tuning upgrade available at BAS & I |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 ![]() ![]() ![]() |
Uploaded the new software and left the. 10mil EGR blanking plate in place, just been for a long blast out and what a difference!!!
![]() Cars smoother on acceleration, seems to pull better through the gears and unexpectedly seems a lot smoother on lift off ![]() More test miles over the next few days and will report further but at the moment NICE!!!! ![]() ![]() |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Pete, some feedback on the EGR shut map, much smoother, quieter and more responsive, even mpg appears to have improved!! Still have a flat spot around 2500 rpm. This is accentuated in taller gears, worst of all when changing from 5th to 6th on the motorway. The gear change lands the revs at almost exactly 2500 and speed decreases from 80ish to about 70, before the revs begin to recover. If I change earlier, the engine appears to pass through this range much easier, but I like going fast!? Cheers - overall verdict - very happy customer
Pete is still working with me on this and I have made a couple of changes to date. I had an Allisport intercooler with ITG filter, Safari snorkel, Twisted straight through exhaust, cat back and BAS EGR reduction plate. I have replaced the ITG with the original filter and the EGR plate with the original gasket. Since then Pete has worked on the map to work in harmony with the other mods. By all counts my issues are not normal, but I guess anyone else with similar issues should contact Pete for assistance.
Pete, could this EGR shut command be programmed into and be used with something like BBS's Sync-Mate, basically a stand alone product which could be installed and taken off with out the need for a remap interface? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Peter
If I came to you could you apply just the egr shut remap? Mike |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
any more new info i think im ready to roll with it just hope it will work with all my mods
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 ![]() |
Hello. my question is. EGR can cancel 100%. thanks http://www.clublandrovertt.org/index.php?a...ype=avatar
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Yes i can do it, i will release in a few weeks when i have finished a few things off.
Pete |
Ohh now i feel bad, ive only just seen your post that i didnt answer and you have sold your car. Please accept my appols mse for not answering i didnt see your post untill now. Sorry. If you do keep it yes no problem. Pete |
thanks. Be aware of the issue. http://www.clublandrovertt.org/index.php?a...ype=avatar |
Hello. Well, if I see the issue is that after voiding the engine gives the EGR fault, but not immediately and no way to give the reason, everything points to this that comment. EGR opening force has to raise the temperature of air in the collector. If the ECU does not detect this increase, after a failure so time passes.
To avoid this, you must a microcontroller that after receiving the servo signal of the EGR, it intercepts the signal from the intake manifold temperature and artificially cause a slight increase in temperature. This increase would first real measure of how phenomenon to learn more or how much and then emulate the micro. It's easy, wonder why nobody has thought about. An attempt was this? http://www.clublandrovertt.org/index.php?a...ype=avatar |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
The EGR being shut has a minimal effect on EGT's being produced. Higher EGT's come as a result of increasing engine torque/power over standard, and this is far more relevent than the increase you'd see from isolating the EGR system.
There are strategies within the puma engine management to reduce engine torque should coolant / Cylinder Head Temps become too great, hence helping to prevent engine damage through excess heat. With our EGR shut software modifications, it is easily reversible by simply reflashing the PCM software with a version that enables EGR actuation. I expect Pete's solution allows this as well, in a very similar way. Any physical engine modifications to isolate the EGR are also easily reversible. Regards, Gary. |
Is Piter at what this one being employed in the software? And this honest: he become a microcontroller who after receiving sign in the servo of the EGR, intercepts the sign of the temperature of the collector of admission and to provoke of artificial form a light increase of temperature. This increase it would be first that to measure of royal form to know more or meno all that is and to emulate it then with the mike. http://www.clublandrovertt.org/index.php?a...ype=avatar
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 ![]() ![]() |
Anyone do a Mac OS based system yet
