Home > Puma (Tdci) > Another output shaft failure...
Page 2 of 10 <12345678910>
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Likeomg wrote:
Wild Card 90 wrote:
Sorry to hear that. 41 K! The horrible thing is there is no ryme or reason as to how long a shaft will last. We will be doing a several thousand K trip towing a 2.5 T trailer soon, and already I´m thinking what to do in the event....
Shame on you JLR!
if i was in your position id probably get the ashcroft upgraded one fitted before i set off on big trips with a large trailer...
I had the Ashcroft kit fitted to mine a couple of months back... Dave and his chaps were superb in the service I got.. Not the cheapest fix, but I know it'll never run dry.. Unless the gearbox dumps its load on the road!!
Here are a couple of pix of the removed shaft and coupler...
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #532442 17th May 2016 7:37pm
Fish13
Scotland 2012 Defender 90 Puma 2.2 HT Tamar Blue
Thanks Shax,
I'll post pics of mine when it's done. Parts were ordered today, hopefully done tomorrow.
This one lasted 41k dry, so hopefully get a lot more out of one that's greased! If it feels anything like it did again, I'll buy the Ashcroft one in advance.
Has anyone fitted a properly greased one and what mileage have you gotten out of that? Curious to know!
Cheers,
Fish.
Post #532477 17th May 2016 8:45pm
Fatboy Slim
Wales
Hate to say it, but I've found greasing them a waste of time. Unless you can keep greasing it the grease just dries out and becomes a rusty grinding paste on the splines.
Post #532479 17th May 2016 8:58pm
shaggydog
Raising my head above the parapet...
Would there be any advantage instead of greasing them but to bond them together?
I'm sure Locktite would have an appropriate substance which would lock the two together? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #532616 18th May 2016 12:44pm
I really don't think it would last. I once tried Loctiting the drive flanges onto the ends of the halfshafts thinking it might reduce fretting. It did, but only for a couple of miles.
I wondered about the feasibility of cross-drilling through the whole joint and pinning or bolting through it.
Post #532622 18th May 2016 1:09pm
nickhodgson
What are the two studs welded on to the coupler for? To get the coupler off and is that the only way? What if you just want to grease the coupler? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #532631 18th May 2016 1:32pm
Cupboard
Could use something a bit more flexible? But maybe that would just wobble, wear and fall out as dust.
It can't be the only way, my local bloke with a garage called Tim managed to change mine without them. He's not a Land Rover guy, just a useful bloke.
Post #532662 18th May 2016 3:21pm
The correct way is to use a special tool to hold it while undoing (or doing up) the retaining bolt or screw, and then to use a conventional puller to pull it off the gearbox splines.
I shudder when I see some of the blacksmith bodgery used for some jobs!
Post #532675 18th May 2016 4:19pm
Shax
They were welded on by the fitters to pull the duff coupler off..
looks drastic, but it works!
One thing to make sure is that you do not nick the oil seals when fitting... The newer kits have been modified to reduce the likelyhood of this happening, but lets be careful eh!!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #532724 18th May 2016 7:54pm
Fish13
An update as it came apart today - seems a pretty bad example compared to some others I've seen on here...
Post #532792 18th May 2016 9:51pm
Morepower
New Zealand
Wonder how long before one of these units fail and somebody gets seriously hurt... All for the sake of some accountant saving 2p per vehicle... I'm frankly shocked LR don't do a safety recall...
Imagine the field day the press could do with this known fault....
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #532806 18th May 2016 10:19pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
what grease were you using? 1953 80"
1987 mini city e
2011 90"
Post #532809 18th May 2016 10:23pm
Fatboy Slim
Wales
Tried pretty much everything. Caterpillar desert gold lasts the longest but still not the answer. Unless you can keep greasing it periodically it'll just dry out and wear no matter what you do. FYI some of our site vehicles were lucky to get 5000 miles out of a shaft. Rubbish bit of design. The casing between the two boxes should be sealed and full of oil.
Post #532811 18th May 2016 10:30pm
MadTom
Using Loctite - look at the Discovery 2 halfshafts. They are loctited to the hubs. But it was designed this way. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #532876 19th May 2016 9:17am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Is this still a problem with the latest vehicles 14, 15 and 16 plate or have LR fixed it?
Post #532882 19th May 2016 9:55am
