Home > Puma (Tdci) > TDI transfer box on a Puma TDCI? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
The high ratio gearing is different, the Puma is 1.222:1 1988 90 Td5 NAS soft top
2015 D90 XS SW |
11th May 2016 11:46am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
It should fit though. You may have to modify the wiring to the Diff Lock Switch and will have to use the Puma Speedo Sensor.
The gearing will make your engine revs higher for the same speed when compared to the old Puma Transferbox. Depending on how you use the car this might not be a problem. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
12th May 2016 8:10am |
Kirby0016 Member Since: 11 May 2016 Location: Lisburn Posts: 2 |
Thanks for the advice guys, the main concern was would it fit. So it will be going on soon and i'll let you know how it goes.
26th May 2016 1:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
You are going to have an exceptinoally low first gear!
26th May 2016 4:38pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
unless its a disco tdi tbox it will more than likely be a 1.4 box. old 110 could be a 1.6 but not many of them about now. Puma as std is 1.2 as above.
if you do a fair amount of work over 50mph it will work harder. 1st will become redundant. assuming you have 31" tyres as std. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th May 2016 7:27pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
newbie here.
but itn't the low gear ratio a good thing when it comes to offroading? because my friend with Patrols always brag about their 85% reduction gear.... |
27th May 2016 6:30am |
also what if I change the tyre to 35? to be more exact, what is the difference between changing transferbox gear ratio to changing diff ratio? any pros and cons? cheers |
27th May 2016 6:35am |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Well you've got low range... Changing transfer box ratio has a similar effect to changing diff ratio (in high range) it's just the speed reduction happens in a different place. I think I'm right in saying they all have the same low range ratio. |
27th May 2016 6:47am |
Did it work out? 1995 300tdi Defender 90 P/UP
27th May 2016 7:38am |
correct they all have same low range ratios 3.32 for std 1.4, 1.6 and 1.2s Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 28th May 2016 6:56am. Edited 1 time in total |
28th May 2016 6:54am |
Try a gear ratio calculator 1.4 with 35s would work far better than the 31s with 1.2 box. i am not sure on exact difference will see if i can find the ratio calculator. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th May 2016 6:55am |
will hopefully work
https://www.defender2.net/gallery/albums/u...ulator.xls Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th May 2016 6:58am |
from what i can see 31s on a 1.2 against 35s on a 1.4 are near enough the same from above spreadsheet Cheers
28th May 2016 7:01am |
