Home > Puma (Tdci) > TDI transfer box on a Puma TDCI?
Kirby0016
United Kingdom 2005 Defender 110 Td5 SW Alpine White
Hi,
The transfer box on the Puma has died, and there happens to be a TDI transfer box knocking about the farm, does anyone know if it would be compatible with the TDCI gearbox or does the fact that the donor gearbox was 5 speed and the TDCI a 6 speed make it an unlikely pairing?
Thanks,
David.
Post #530627 11th May 2016 11:41am
Martin
Site Admin
The high ratio gearing is different, the Puma is 1.222:1  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #530632 11th May 2016 11:46am
nickhodgson
It should fit though. You may have to modify the wiring to the Diff Lock Switch and will have to use the Puma Speedo Sensor.
The gearing will make your engine revs higher for the same speed when compared to the old Puma Transferbox. Depending on how you use the car this might not be a problem. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #530895 12th May 2016 8:10am
Kirby0016
Thanks for the advice guys, the main concern was would it fit. So it will be going on soon and i'll let you know how it goes.
Post #534878 26th May 2016 1:59pm
You are going to have an exceptinoally low first gear!
Post #534915 26th May 2016 4:38pm
jst
unless its a disco tdi tbox it will more than likely be a 1.4 box. old 110 could be a 1.6 but not many of them about now. Puma as std is 1.2 as above.
if you do a fair amount of work over 50mph it will work harder. 1st will become redundant. assuming you have 31" tyres as std. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #534947 26th May 2016 7:27pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
newbie here.
but itn't the low gear ratio a good thing when it comes to offroading?
because my friend with Patrols always brag about their 85% reduction gear....
Post #535070 27th May 2016 6:30am
tuesdayfox
also what if I change the tyre to 35?
to be more exact, what is the difference between changing transferbox gear ratio to changing diff ratio?
any pros and cons?
cheers
Post #535072 27th May 2016 6:35am
Cupboard
tuesdayfox wrote:
newbie here.
Well you've got low range...
Changing transfer box ratio has a similar effect to changing diff ratio (in high range) it's just the speed reduction happens in a different place. I think I'm right in saying they all have the same low range ratio.
Post #535073 27th May 2016 6:47am
nickhodgson
Did it work out? 1995 300tdi Defender 90 P/UP
Post #535081 27th May 2016 7:38am
jst
correct they all have same low range ratios 3.32 for std 1.4, 1.6 and 1.2s Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #535322 28th May 2016 6:54am
jst
any pros and cons?
cheers
Try a gear ratio calculator
1.4 with 35s would work far better than the 31s with 1.2 box. i am not sure on exact difference will see if i can find the ratio calculator. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #535324 28th May 2016 6:55am
jst
will hopefully work
https://www.defender2.net/gallery/albums/u...ulator.xls Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #535326 28th May 2016 6:58am
jst
from what i can see 31s on a 1.2 against 35s on a 1.4 are near enough the same from above spreadsheet Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #535327 28th May 2016 7:01am
