![]() | Home > Puma (Tdci) > Inexpensive puma gear knob solution? |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
![]() Click image to enlarge Hi. As in the picture my Puma gear knob has been perished/ cracked probably due to excessive heaty climate these days and as a temporary solution I have glued together but doubt how long it lasts. I noted that to change just the damn gear knob you have to change the whole gear leaver as a kit which I found very costly. I'm sure it will perish again even I replaced. Has anyone got an inexpensive simple solution just to replace this crappy knob.? |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
There was a thread somewhere about cutting it off to expose the shaft inside, its not threaded tho apparently so you'd end up either gluing one on or cutting your own thread into the rod, possibly not the most elegant solution but likely the cheapest.
Found it its on AULRO. 3 Landrovers |
any link?
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2654 ![]() ![]() |
how much is the kit?
i have one lying around that i could part with... |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Wrap it with Baco foil and put a red & yellow ring at the base and your life will be at one with the Spirit world. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
/\/\/\what she said,lol. Pov.spec,ftw. 2006, 110,TD5.
You've just burst my bubble. A Scotsman with a great sense of humour. Great post Alex, thank you. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
AlexSmith Member Since: 05 Sep 2013 Location: Arroio do Meio, RS Posts: 47 ![]() ![]() ![]() |
They say this end is compatible with the Defender, but I'm not sure how it would fit... Worth a try for the price though...
http://www.ebay.co.uk/itm/380839995311 ![]() Click image to enlarge 2020: Defender 110 SW 300 Tdi 2004 Alpine White 2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray 2002-2005: Defender 90 CSW 300 Tdi Dark Green |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 ![]() ![]() |
Hi,
I have loads of these brand new from auto conversions, £25 each + carriage I am now off for a week but if you want one email me a week on Monday Dave Dave |
BADCADI Member Since: 30 Dec 2020 Location: Munich Posts: 32 ![]() ![]() ![]() |
Resurrecting an old thread:
Does anyone still have some replacement gear lever/knobs, or found a good solution to the gear know disintegrating issue? Thanks. BADCADI |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17565 ![]() ![]() ![]() |
Thanks blackwolf ..... not ready for that 'drastic' solution just yet, but will certainly keep in in mind.
Samblers Member Since: 29 Jan 2014 Location: Perth, innit Posts: 63 ![]() ![]() ![]() |
I just fixed mine using a kneadable 2-part black-coloured epoxy called PC-7 (from USA)
It was cracked all over and a chunk had fallen off. I glued the chunk back on and filled up the cracks, wiped off the excess. Actually looks quite OK now and the epoxy dries hard, meaning it feels fine too |
