Home > Puma (Tdci) > Inexpensive puma gear knob solution?
Page 3 of 5 <12345>
It's not a pool ball, it's a classic gear lever knob!
Post #965742 22nd Sep 2022 7:00pm
Eduardo
jajajaja Laughing Laughing Laughing
I`m in the same boat now, the gear knob starting to fell apart after several years with cracks.
Probably I will take the Jeepy approach using the 12mm insert to put a new knob
¿Someone have pictures of the insert?
Cheers!
Edit:
I found it...
 Eduardo
Post #986603 23rd Mar 2023 11:03pm
Jeepy
France 2008 Defender 110 Puma 2.4 SW Keswick Green
Post #986611 24th Mar 2023 6:41am
Eduardo
Thanks Jeepy
How do you fix the knob to the rod?
My first attempt of Knob using the 3D printer looks Ok in the shape but a little small. I will repeat the print but bigger.
Cheers!
 Eduardo
Post #987824 3rd Apr 2023 7:40pm
hornet
I recommend a 12mm thread (like Blackwolf did), for your solution you can use a "Rampa-Muffe" (do not know the expression in englisch, do a search with that to understand what i mean) to mount your knob or select an inner diameter of your knob that enables you to push it snug onto the axle, maybe with an adhesive.
Try to adapt the "formm follows function" philosophy of Porsche if you create something new Thumbs Up
Post #987856 4th Apr 2023 7:52am
Ianh
In English a "Rampa-Muffe" would equate to a “Self tapping threaded insert” , but I much prefer the sound of a "Rampa-Muffe" Very Happy
Post #987884 4th Apr 2023 11:56am
Jeepy
Just 2 screws for stop rotation ,simple is best Laughing
Post #987925 4th Apr 2023 5:46pm
hornet
Nice, ideally you hit one of the existing recesses? Note, the headlight adjustment is activated Wink
Post #988011 5th Apr 2023 12:11pm
Jeepy
Just with this,screw tight insert is soft
Thanks Wink
Post #988051 5th Apr 2023 4:50pm
Eduardo
Thanks to all!!!!
Im now in the process to print the 2nd attempt.
Hope I got the right size now.
Cheers from Chile Eduardo
Post #988088 6th Apr 2023 12:03am
Eduardo
First attempt!
Next one will be longer to hide the rod and with an insert to attach the screw, but in general terms looks OK. (take out the plastic is difficult but doable).
Cheers to all Eduardo
Post #988155 6th Apr 2023 4:53pm
Eduardo
2nd attempt
Looks OK now.
Thanks to all for the ideas! Eduardo
Post #988485 10th Apr 2023 1:24pm
Klein Kameel
South Africa
Hi Eduardo
Are you willing to share your file or perhaps sell it to me as I'm in the same situation with my gear knob.
A friend of mine have got a 3D printer and he can do the printing for me.
Regards
Andre
Post #988760 12th Apr 2023 5:36pm
Eduardo
No problem Klein!
Give me an email and I sent you the file
Cheers! Eduardo
Post #989835 21st Apr 2023 3:54pm
Klein Kameel
South Africa
Thanks Eduardo
It is andre@celsusimago.co.za
Regards
Post #989852 21st Apr 2023 7:51pm
Page 3 of 5 <12345>
