Home > Maintenance & Modifications > clutch pedal still squeaky after 3 in 1
Page 1 of 3 123>
Stacey007
Hello
I had a squeaky clutch pedal months ago, did a search and found the 3 in 1 oil dripped on the clutch from under the cover (6 bolts) normally did the job for a while.
Just squirted some more on it yet its still squeaks... annoyingly.
Any think else I can do? Squirted some on the spring above pedal also. Still squeaks
Post #517763 25th Mar 2016 7:48pm
Landy-Novice
my 200tdi did the same even after i oiled it. but even more oil fixed it... Rolling with laughter
i had to oil it a few times on all the moving parts and it did go, dount hold back with the oil. Thumbs Up
Post #517768 25th Mar 2016 8:02pm
VeeTee
Netherlands
Just did min too. You haven't used enough oil unless there are oil stains on the rubber mat under the pedal Laughing Thumbs Up Cheers, Vincent
MySite
Post #517770 25th Mar 2016 8:12pm
Stacey007
^ it was dripping in.... not a huge amount.
Do you get someone to press the clutch inside? while squirting it as I was doing it on my own. Squirt then press clutch,
Hopefully it will sort itself after a drive tomorrow. otherwise I will do it again...
Smile
Post #517771 25th Mar 2016 8:16pm
VeeTee
Netherlands
^ No, did it the same way. Give it some time to penetrate, otherwise repeat... Wink Thumbs Up Cheers, Vincent
MySite
Post #517774 25th Mar 2016 8:20pm
Happyoldgit
It's not always the pivot so try this:
Open the drivers door and from outside the vehicle take a look at the clutch pedal - see the spring [overcentre type on later vehicles] some way up the pedal shaft? Apply a drop of lubricant / service spray where the spring acts on the pedal.
Keep an eye and make sure that by dropping mineral oil onto the pivot you keep it away from the master cylinder itself - especially the rubber bits. Steve.
http://forums.lr4x4.com
Post #517791 25th Mar 2016 8:54pm
ericvv
Post #517792 25th Mar 2016 8:54pm
Stacey007
^ That's interesting
Does having the bleed nipple though just bypass undoing the 6 screws and squirting oil in?
Should mine have that 'blank'
Thanks
Post #517794 25th Mar 2016 8:58pm
Happyoldgit
^^I've fitted a grease nipple there on some previous vehicles but while a worthwhile, cheap and simple mod the problem often lays with the spring Wink Steve.
Post #517795 25th Mar 2016 9:02pm
LR90XS2011
ditto the spring
I cure my squeak by lubricating just the spring didnt need to even open the bonnet DEFENDER 90 TDCI XS,
Post #517801 25th Mar 2016 9:19pm
Stacey007
Ok so oily rag under pedal and squirted 3 in 1 all round where I normally do ( undo the 6 screws under engine..... Squirt) and I squirted a lot.
Every time previously this has worked but NO
So head under steering wheel as I push the clutch in with hand and squirt the spring also (and anything else I can see that could be causing a squeal attached to pedal)
STILL squeaking....... Aaarrggghhh any other options?
Post #519403 30th Mar 2016 9:26pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I sprayed mine with lithium grease from the inside and this worked a treat.
Post #519423 30th Mar 2016 10:12pm
Happyoldgit
Both ends of the spring? Next would be check the security of the pedal box fastenings but I'd still put money on the spring.
BTW as I said before you don't want to get mineral oil [like 3 in 1 ] near the master cylinder pushrod at the rubber boot end or the boot itself. Steve.
Post #519500 31st Mar 2016 9:18am
Stacey007
^ I'm guessing the amount of WD40 and 3 in 1 I've tipped down this its inevitable that some has gone beyond the rubber?
not much I can do about that now I guess?
I think its the spring also but at a loss how to solve it now Sad and its annoying...
This isn't my car but shows where I have squirted stuff...
Post #519508 31st Mar 2016 9:32am
Happyoldgit
That plastic insert in the pedal circled in yellow is a favourite spot as the insert can wear or breakdown. The spring coils themselves can also creak and groan too. There is a knack to removing the spring for a check over, it's more fiddly than difficult.
WD40 is more of a water repellent than a lubricant, if what you are using hasn't worked then try something else like a spray white grease but only use it sparingly inside the pedal box itself and keep the stuff away from the master cylinder!
If I were you I'd give the pushrod and rubber dust boot a thorough wipe over, the danger with using lubricant in that area is that some might get drawn into the cylinder bore which won't do the piston seals any favours. Steve.
Post #519530 31st Mar 2016 10:57am
Page 1 of 3 123>
