![]() | Home > Maintenance & Modifications > clutch pedal still squeaky after 3 in 1 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
OK,
One last try on Friday, I really hate the noise it make (wife and kids think its fine) but me... nope have to sort it. So Greased the pedal spring everywhere I could head under dash, screw driver opening the spring a little as I pushed the clutch down with hand and spread grease over it. I needed 3 hands but the annoyance that is this squeak I managed.. Then head under engine in clutch box again !! more grease (cough cough a few squirts...) Result...... Its oooh sooo quite ![]() ![]() ![]() Lets see how long this lasts !!! |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 ![]() ![]() |
What an excellent forum this is
![]() I just spayed some WD40 on my clutch pedal spring and under the plate held by 6 screws on the master cylinder and my pedal is smooth and quiet again ![]() I've no doubt that the benefit of WD40 will be short lived so I'll get some spray grease in ready for next time. Now gone - 2012 2.2 110 DC XS |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10934 ![]() ![]() |
+1 ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
El Rey Member Since: 25 Aug 2015 Location: Gunbarrel Highway Posts: 60 ![]() ![]() |
If I understand you correctly - what about the folk who put in a grease nipple and fill up the box with grease? Wouldn't that inundate the whole thing with lubricant? |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
The grease gobs drop down on to your foot before it goes up that far
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1862 ![]() ![]() ![]() |
Scott, did your squeak come back? I need to sort mine as its been doing it for months
![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Wonderful! But to follow on, doesn't that mean installing a nipple and pumping in grease is not much good, since the grease won't get up onto some of the mechanism? |
Took the cover off the box in the engine bay.
Warning to anybody else out there - in my MY2015 110 the gasket made it bloody hard to prise the cover off. For a little while I thought it wasn't going to come away. I ended up having to put some needle nose pliers down one screw hole and lever it up. Then I was worried I was going to tear the gasket as it slowly came away because it was stuck down so firmly. And a magnetized screwdriver is your friend when you're putting the screws back in. It's a fiddly space and there's a fair risk of one or more screws disappearing into the engine bay (and hopefully down onto the ground). Anyway long story short, that's not the source of my squeaks. I lubed it all up and the squeak is still there and still definitely coming from somewhere very close to the clutch pedal. Will take the insulation cover off inside the cabin next and give the spring a go. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
I've tried everything everyone here has suggested. None of it worked.
However what did work was greasing the main pedal pivot - and no it doesn't mean taking everything apart. If you feel down the inside of the pedal box - from inside the engine bay, you will feel the end of the shaft that the pedal rotates on. It's hollow, and seems to have grease ports inside it out to the bearing surface. The end of that shaft is in fact threaded for a grease nipple but LR - in their wisdom - just bung some sealant in there instead. If you prise the sealant out, put a grease nipple in, you can inject grease into the pedal pivot. It's been covered on here before:- http://www.defender2.net/forum/post469048.html And here for more photos:- http://www.4x4community.co.za/forum/showth...utch-pedal Dave Green Goddess - 1998 Defender 110 300tdi |
Now I finally get it. I thought the nipple would direct the grease into the box - but it's into the shaft.
Cheers for the update. Do you have any notions how to remove the silicon from the thread so the nipple can screw in - without taking the whole assembly out? |
There wasn't that much sealant in there - in my case a fingernail extracted it easily. Dave
Cheers - will give this a crack once I have a nipple.
Lem Member Since: 17 Jul 2016 Location: Brisbane Posts: 3 ![]() ![]() ![]() |
Great forum!
If you don’t want to wait for the grease nipple, you can try this.......I had the silicon sealant plugging up that hole so I poked a small skewer into the middle. It created a hole big enough to insert a plastic nozzle from the lithium grease spray can. The can was upside down but still managed to get a few bursts directly inside. The squeak took a few days of driving but it slowly disappeared. I tried all this after replacing the clutch pedal spring and bushes (that was a real pain), but it did not solve the issue, I was convinced that the noise was coming from the spring. I also tried rubber grease etc etc. I was ready to go the grease nipple and thought I’d give the lithium spray a go. Hope you get it sorted. |
