Home > In Car Electronics > Fitting tweeters - TD5 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
They're 130mm edge components. Just cheap ones from halfords but they don't sound too bad. Eventually I'll do a full blown focal setup 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Feb 2016 10:52pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5881 |
If I did decide to fit speakers in the lower part of the dash what size holes would need to be cut? 1999 Defender TD5 110
4th Mar 2016 1:18pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I fitted Focal tweeters,in the same place as Pumas.Think I used a 40mm hole saw for an absolute perfect fit,didn't need mastic or anything!!
Also fitted 5 1/4 inch (130mm) speakers in place of the originals (4 inch,100mm),only needed to slightly widen the original holes,(+25mm mdf speaker rings).Trim the thin foam and easily snip the 1mm metal backing with cheapo wire cutters/tin snips. Pov.spec,ftw. 2006, 110,TD5. |
7th Mar 2016 5:20pm |
Thanks JimBob7. For those Defenders without speakers (Poverty spec?) do the dashboards come marked where the speakers need to go? I.e is there a moulding mark somewhere? 1999 Defender TD5 110
7th Mar 2016 8:39pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
No Td5s had tweeters on top of the dash and there are no marks to tell you where to put them, I just spaced them equally from each end so they looked OK. Ray
7th Mar 2016 10:10pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
im interested in doing this but a little confused as to how you wire the tweeters up to a head unit can anyone explain?
2nd Oct 2017 2:52pm |
Puma tweeters with crossovers built in wired in parallel with main speakers
Click image to enlarge |
2nd Oct 2017 3:16pm |
Ah ok so you basically piggy back onto the main speaker connection or join the wires together?
2nd Oct 2017 5:42pm |
Yes + to + and - to -
2nd Oct 2017 6:07pm |
They sound good what were they make/model wise? |
1st Nov 2017 9:51pm |
